DRW to SRW conversion
OK tired of bent dually wheels, tired of burning up 6 tires at a time, I am going to convert to single wheel.
Are the front Dana 60s the same? can I just buy hubs and rotors for the front axle? are the spindles and stub shafts the same? any help is appreciated.
Dana 80 single wheel for the rear, gearing won't work to use the GM 14 bolt.
The 14 bolt was used in 3/4 ton up GM trucks.
My question is will the wheels you put on the front run on the rear. im not sure how the dodge and GM a 8lug singles transfer back and forth.
Ha ha i dont think there ever has been a set of factory wheels made that has been true and this comes from owning and drivin almost nothing but duallys(ford,GMs, and dodges).
BTW, moving back to the Austin area soon, this sorry assed state (Colorado) just charged me $267 to put plates on my truck!!!!!
ha ha well i hate to say it but Austin has gotten to be just about the same. I gotta plate mine this month luckly i run farm truck so its a lil cheaper still. oh and you are supposed to have a muffler on diesels now just a lil fyi
Actually it is Red Rock, I have a muffler, it's called a turbo!!!!
nope no more they have changed that law in texas it now reads in the inspection handbook that if equipped with a turbo it must also have a muffler.
There are still a few who will pass it without but its getting few by the day. where is Red Rock by the way?
The spindles, lockouts, stub shafts, bearings, etc are all the same on DRW and SRW.
I'm assuming you have 3.55 gears if a 14 bolt won't jive
Yes, all you have to change is the hubs and rotors. I don't know if you meant buying them new or junkyard, but they are not cheap. You could reuse your dually rotors, but you'll have to drill the 8 holes out larger to fit the wheel studs.
I still have a couple friends who do inspections. Another trick is to take a HD truck muffler, slide it over the pipe and weld the ends to the straight pipe, looks legal with no flow loss!!! I do it with catalytic converters on my Camaro.
I C. i grew up going to rices crossin/ taylor and cameron/ thorndale area. Yeah ive got a few that still do inspections but im goin along the same lines gonna take a semi renator and clean it out and slap on there.
lawdog800
19
Mar 31, 2011 09:26 AM
89dieselkong
Apr 5, 2009 05:20 PM
dragginlx
15
Mar 9, 2007 11:32 AM
