Driver door
Old Mar 28, 2016 | 12:19 PM
loudhornsrule's Avatar
Driver door
Replaced drivers door with a non power window door. Has manual crank and lock. My problem is now cant work the electrics on RH door w/ RH controls. Fuse is good . I Did clip some of the wires in original door. Any suggestions
Old Mar 28, 2016 | 01:23 PM
j_martin's Avatar
The drivers door had a switch in it for the passenger side door. They are interlocked. You have to get into the diagrams and splice together the wires that went to normally closed contacts in the above said switch.
Old Mar 28, 2016 | 01:32 PM
Ok That makes sense Thank You
Old Mar 28, 2016 | 02:30 PM
gyman98's Avatar
Like he said, the drivers door harness goes over to about the glove box and plugs into the right hand door. You might be able to modify the harness at that point
Old Mar 28, 2016 | 03:31 PM
maybe368's Avatar
I replaced a power window door with a non powerd one, but I moved over all of the parts. It was pretty easy to do, but I needed to buy one of those giant pop rivet tools. With that tool it was real easy to do...Mark
Old Mar 28, 2016 | 05:31 PM
Okay, I'm confused
You replace a door with a differently prepped door, cut Some wires in the original door, then you call the new door a ??
that's like going to the underwear store to buy new jockeys, you pick up a Victoria's secret thong, get it back home and claim that the new undies don't fit, so they must be bad...
Geesh.....
I guess that frequent use of loud horns can alter ones common sense approach to tasks at hand
Last edited by BC847; Mar 28, 2016 at 06:40 PM. Reason: Removed shortcut to profanity
Old Mar 28, 2016 | 07:29 PM
Let me break it down for you Toxic. I figured out once you unplug the switches on the driver's door then the power is dead to the passenger door. So, I did figure it out. Don't be so confused. Was looking for some help not a bunch of hoopla from You NJ Good Day
Old Mar 28, 2016 | 07:49 PM
j_martin's Avatar
I intend to install a 4 bell train horn. I'm tired of people not being able to see 65 feet of double bottom coming at them.
Old Mar 28, 2016 | 08:14 PM
[QUOTE=j_martin;3300317]
I intend to install a 4 bell train horn. I'm tired of people not being able to see 65 feet of double bottom coming at them. Get yourself a Leslie or Nathan horn Real Deal
nomad65
Aug 20, 2007 06:01 PM
TxDiesel007
Jul 31, 2005 05:59 PM
CTDHokie
Aug 23, 2004 07:31 AM
NJMurvin
Aug 14, 2004 06:13 PM
v12xke
Mar 1, 2004 03:46 PM
