Driver's door rattle
Old Aug 11, 2004 | 12:33 PM
NJMurvin's Avatar
My truck has developed a pretty irritating rattle in the driver's door. I can't really tell if it's the window or something else rattling. It rattles whenever there's drivetrain vibration (going thru 2k rpm on acceleration thru the gears and at the infamous 70-75mph).
Is this something I can easily fix myself or should I venture into the dealer?
Thanks,
Neil
Old Aug 11, 2004 | 01:59 PM
BAD DSL's Avatar
I have been experiencing the same rattle , is yours more pronounced with the beats of the radio? when I find a spare moment I'll be pulling that door off to investigate. When I do I'll post my findings
Old Aug 11, 2004 | 02:15 PM
DFD536's Avatar
Try this, just "bump" the switch for the power window down, not far enough for wind noise, but it will likely stop the rattle. seems when the window is all the way up, it pushes on the weatherstrip, and makes it rattle
Don't ask, but I saw it here, and it works.
Dennis
Old Aug 11, 2004 | 05:58 PM
NJMurvin's Avatar
DFD536,
I'll give it a try.
BAD DSL
Let me know what you find out and how hard it is to get the door panel off. I'm tempted to upgrade my speakers. This may just be the motivation I needed.
Thanks,
Neil
Old Aug 11, 2004 | 06:50 PM
PapaPerk's Avatar
Radio Rattle
Bad DSL
I have the radio rattle too! It is in the drivers door. It really ticks me off! Other than that the truck is rattle free so it is really not that bad. But I want to fix the problem. Been thinking about taking it to the dealer but I hate thinking of them tearing the whole door apart. May cause more rattles!
Hope someone comes up with a quick fix.
Old Aug 11, 2004 | 08:12 PM
LinearX's Avatar
I've got the radio rattle, and I've found that if I put my fingers on the window controls the rattle stops. That makes me think that the wires for the controls are what's causing the vibration, or the switches are loose and causing it.
Old Aug 11, 2004 | 10:53 PM
Jmac's Avatar
I had a rattle where the rubber meets the window right behind the plastic where the inside bolts to the mirror are.
If you stick your fingers into the into that area and create pressure b/w the windo and the rubber the rattle stops.
If the you bump the window down 1or2 millimeters the rattle stops.
I fixed this by loosening the bolts to the window(not taking them all the way off) you'll notice a rubbery little gasket on the outside portion of the mirror housing. The gasket isn't thick enough to create a good seal to keep out wind and rattle. I left the seal in but beefed it up by stuffing some 1/2 inch window weather stripping in there and bolted it all back up. Problem solved no wind or rattle for 2 weeks so far.
PS I didn't remove the door panel (didn't know how) but gently bent the plastic back enough to get to the mirror bolts. . . wasn't easy but paitence is a virtue.
PM me for further details
Jamie
Old Aug 14, 2004 | 06:13 PM
Mark Thomas's Avatar
I popped the window, door lock control pad off and stuffed insulation in there with a stick to push it all over then used my hands, no rattle any more!
nomad65
Aug 20, 2007 06:01 PM
LanceK
May 17, 2007 01:54 PM
CTDHokie
Aug 23, 2004 07:31 AM
v12xke
Mar 1, 2004 03:46 PM
