Drifting upon heavy breaking. What gives?
Old May 25, 2007 | 10:33 AM
bigragu's Avatar
When I step hard into the break I tend to pull to the right upon coming up to a stop. Diagnose?
Old May 25, 2007 | 11:35 AM
Tuckerdee's Avatar
Possibly a stuck left front caliper.
Old May 25, 2007 | 11:52 AM
Ramdriver15's Avatar
caliper or pins on the left side
possible stuck ebrake cable or shoes on the right rear....
BHD's Avatar
BHD
Might sound funny but also check rear shoe adjustments.
Old May 25, 2007 | 12:16 PM
airmen65's Avatar
miss-alignment, i know my yota pulled to the left because it had gear oil on the brake pads.
Old May 25, 2007 | 12:19 PM
Rampage1967's Avatar
Yes, check rear brake ajustments . . .when one side of mine gets out of adjustment it does that . . .soon as my rear hub nut socket gets here i will fix the adjusters.
Old May 26, 2007 | 05:03 AM
KRB's Avatar
KRB
Don't forget those rubber flex lines. They can deteriorate with age and swell inside or weaken and expand and reduce the fluid pressure to one side. I've had that happen before.
Probably not a bad idea to replace as a maintenance item. There's another set going from frame to axle too but those wouldn't affect just one side. I remember a thread somewhere recently about steel braided ones .
I replaced the ujoint on the front axle of my M880 (Dana 44) recently and since its mainly a farm truck I just cinched up the spindle nut and planned to torque it down after driving a few times on the farm. Needless to say one thing lead to another and I forgot . The first trip to town with it and the thing wanted to pull to that side. Way too much slop in there and the braking accentuated (sp?) that.
I need to replace the rotors on mine. My steering gets the herky jerkys when I brake hard, especially on a hill or with a load .
Good luck. These things need all the brakes we can give em!
Old May 26, 2007 | 08:24 AM
bigragu's Avatar
Thanks, 1st gen brothers. With all the tips, this sounds like a no brainer.
Old May 26, 2007 | 06:41 PM
loch's Avatar
Not to scare you, but wedsday my truck started doing exactly that. Well after checking everything i was at a loss, untill i got my bro in law to switch from drive to reverse while i was under the truck looking. Well the passenger side upper A-frame broke, right where the bushing presses in, when i jacked it up the top of the tire fell out about a foot.
Point im making is dont over look the simple things assuming its always brake related, suspension can cause exact symptoms.
Old May 26, 2007 | 07:30 PM
G1625S's Avatar
Holy schnikes Good find...and just in time
mikeg135
Oct 5, 2006 09:06 PM
Mav
Sep 17, 2006 11:52 PM
mtl0727
Nov 22, 2005 09:01 PM
DodgingTools
May 3, 2005 12:16 PM
ViperSBT
Oct 8, 2004 04:39 PM
