Door and windshield weatherstrip
I know I can get weatherstrip for the doors and windshield for my '91 W250 from any number of sources but I thought I'd ask if any suppliers stand out as having excellent weather strips which are as close to OEM as possible.
Thanks!
Thanks!
Stay away from door sweeps made by Fairchild...think that was the name...horrible product since they use cheap tin clips instead of the proper spring steel clips. The sweeps will not stay tight against the body so every time you roll the window up they come loose.
I got mine from J.C. Whitney about 14 years ago. They fit very well. I especially like the door seals. They seal so well I have to roll the window down to shut the door. Otherwise it makes my ears pop. The window seals fit perfectly in the guides. The seals along the bottom had to have a slight trimming but that was expected to make a perfect fit.
Edwin
Edwin
I got mine from LMC but like Thrashingcow says my drivers side window sweep keeps popping up when I put the window up.I don’t know who makes them but somebody had suggested Steel rubber products I think was the name but not sure might give them a try
I went with Steel Rubber products at the end of the day. They are more expensive but after recommendations elsewhere I decided it might be worth it.
https://www.steelerubber.com/search?year=1991&make=dodge&model=w250&style=2-door-standard-cab-pickup
[QUOTE=Denis;3369735]I went with Steel Rubber products at the end of the day. They are more expensive but after recommendations elsewhere I decided it might be worth it.
https://www.steelerubber.com/search?year=1991&make=dodge&model=w250&style=2-door-standard. Just curious haven’t seen any feed back on the Steel Rubber products yet
stock600
14
Nov 21, 2007 08:31 PM
Sevir
15
Jan 21, 2006 08:14 PM
