Door hinges
Old Feb 8, 2007 | 10:19 PM
np205's Avatar
Door hinges
Has anyone had problems with the door pins wearing out and the hinges not working right. My dad replaced the pins and bushings but their is still play in them. Are their different pins and bushings, and has anyone had to have their door hinges or doors bent back to close right??? The wind whistle on the drivers side is really anoying .
Old Feb 8, 2007 | 10:24 PM
woodrat's Avatar
Yeah, I have that whistle too. I need a new door or to try and repair this one. there was a good thread about this a while back, look in the stickies.
Old Feb 8, 2007 | 10:59 PM
MBolivar's Avatar
Even though the pins and bushings were replaced, there is probably some play due to wear and tear of the hole in which the pin/bushing goes through. I only had a problem with the lower driver's side hinge. The bottom bushing on that pin was worn and caused the door to sag. I ended up replacing the lower hinge assembly because I had the hardest time removing the original pin. I picked it up from the dealer. NAPA carries the rebuild kit that everyone seems to be using. I haven't had any experience other brands of rebuild kits. Realignment is important too when reinstalling door hinges.
Old Feb 8, 2007 | 11:02 PM
np205's Avatar
Ok, yeah, I think that I might need to get a new hinge because the hole got wallerd out. Thanks for the feed back
Old Feb 8, 2007 | 11:46 PM
woodrat's Avatar
on mine, the door is cracking apart.
Old Feb 9, 2007 | 01:41 AM
MikeThomas's Avatar
Just replaced mine-so much better,even with a little play. Mine does whistle but I have been too lazy to readjust the door-thats all.
Old Feb 9, 2007 | 11:02 AM
justagoodolboy's Avatar
Yes, alot of that whistle can be taken away with good door adjustment, and not just the striker, but the hinges as well. I had the wistle, changed the pins & bushings, and adjusted the top hinge outward (Door In), and the door seals tighter around the front & top of the door and the wistle is gone....
Old Feb 9, 2007 | 11:03 AM
dpuckett's Avatar
Is it door adjustment or old weatherstripping that causes the whistle? I figured it'd be the weatherstripping, but I guess a door grossly out of adjustment can cause it too.
Old Feb 10, 2007 | 10:02 AM
Rampage1967's Avatar
if door is adjusted right check you weather stripping. vent windows also do it . . mine whistle . .
Old Feb 10, 2007 | 11:11 PM
TOMTOM's Avatar
Mine was the vent windo. shimmed the latch and it almost stopped.
TOMMY
Old Feb 13, 2007 | 10:38 AM
4RnrRick's Avatar
This is what happened to mine and how I fixed it....
Lower Door Hinge Repair
https://www.dieseltruckresource.com/...highlight=DOOR
Old Feb 13, 2007 | 11:32 AM
TOMMY
Yep, a quarter under that latch works wonders, and it matches the chrome latch too!!!!
Old Feb 13, 2007 | 12:02 PM
Bill Tomlinson's Avatar
My vent windows whistle if I open them. When I reclose them I push on each part of the triangle and one of the corners will stop the noise if pushed right. I forget which one but it is a constant and reliable thing.
HIJACK - (sorry) someone tried to steal my old girl and popped the vent, breaking the latch instead of the glass. He smashed the plastic shroud around the ingnition and broke of the ring. He could not pull the lock because I had replace d the retaining screw with a tougher one to keep it from falling out. I never expected it to resist a determined thief but it did. You should see the marks he left on it. Looks like he spent an hour on it.
mavrick211
May 29, 2006 08:09 PM
Ram04
Sep 3, 2005 07:26 PM
Scubasteve
Jun 14, 2005 10:31 AM
Jayhawk 490
May 15, 2003 01:22 AM
doodah
Apr 14, 2003 06:29 AM
