Door Hinge
Old Jun 3, 2008 | 01:01 AM
Trooperthorn's Avatar
Last weekend, I helped confedpirate install new bushings and pins on his new crewcab. The doors swung like new and closed well once we got them adjusted. Plan on adjusting your latch pin as well. It requires a large torx.
The older style hinges (seventies vintage) had no bushings and needed to be drilled to accept them. The bushings and pins wer off the rack at a local parts store.
Old Jun 3, 2008 | 08:28 AM
BBrown's Avatar
In my distant memory I think I remember a thread somewhere...
Some machinist-type was rebuilding/redesigning these door hinges. You sent him a "core" and some money and he would return a "super-duper grease-fitting equipt dom-tube hinge.
For now, my NAPA bushings and pins are doing fine - but... anybody remember him?
Bob
Old Jun 3, 2008 | 09:01 AM
apwatson50's Avatar
Bob
I think it was "mysterman" and I believe he was one of the engineers that originally designed these trucks and he had the "super hinge" at one time. I don't know what happened to him now, but haven't heard anything in a while.
Old Jun 3, 2008 | 11:51 AM
fanbrain's Avatar
A fitting name if you haven't heard from him in a while.
Do new bushings and pins help the sagging? I can see daylight from the top front corner of the passenger door.
Old Jun 3, 2008 | 01:23 PM
92red's Avatar
I'm thinking they would help the sagging. I picked up a '93 last night and the driver side sags ever so slightly- no light just yet.
Anyone that's done this have an opinion on how Teflon would work? I've got a bit of it and could turn a couple of bushings out. My question is would it stay put or not?
Old Jun 3, 2008 | 03:38 PM
Jim5870's Avatar
You could use a floor jack or a jack stand to hold up the door while the lower hinge is off.
Old Jun 3, 2008 | 11:59 PM
Study the brass bushings. If you turned the teflon with a shoulder like the bushing has, it really can't go anywhere. Unless, or course it breaks. I do not know how brittle teflon is.
Old Dec 14, 2008 | 07:08 PM
grandpa ralph's Avatar
I need to get the bottom pin out. I have loosened the hinge bolts and beat on the the lower pin with threaded rod and hammer. It doesn't even pretend to budge.
The bottom of the original pin looks different than the replacement. instead of perfectly round, it has one flat side.
Looks like the head of the lower bushing has broke off and over time worked its way down to the bottom of the pin. As I was beating on it, I saw copper next to the pin.
My next thought is cut the pin in half with the sawzall.
Any other ideas?
Old Dec 14, 2008 | 07:17 PM
Stamey's Avatar
I just went through this on my 93, using instructions from this very thread, which I found 2 weeks ago.
My bottom hinge pin would move about 1/8" and stop dead, no matter how hard I beat on it. I found the bottom hinge pin had been crimped a little, so there were, for lack of a better word, "ears" sticking out of the pin below the hinge. I took a die grinder to them, and a file, and removed the "ears" and the pin came right out.
After that, I used a helper to steady the door, sitting on jack stands, took the bolts out of the door on the top hinge, otherwise the pin won't come out due to the curvature of the door, used a punch to pop out the old bushings, the ones that wouldn't just fall out, and used the oil trick between my fingers, as mentioned above.
The door is tight as a drum now. I had to order new striker pins from Napa to replace the worn ones. they should be in tomorrow.
Chris
Old Dec 14, 2008 | 07:18 PM
DNRCustoms's Avatar
Originally Posted by Tron
The bushings area brass and they are porris (little holes..bad spelling) Hold the bushing on the tip of your finger and fill it with engine oil till its full. Then squeaz with another finger and your other hand. Most of the time you can see oil come out of the sides of the bushing. The same is supposed to be done with brass pilot bushing when doing a clutch other wise you end up with a squeak. This just help prolong the life of the door pin bushings.
Boy I wish I would've known that about 6 months ago!! I put all new pins and bushings in and have a darn squeak on the passanger door and wd40 or lithium greese has stopped it... I will keep this in the memory bank for the next time!!
Caincando1
Jul 3, 2017 08:06 AM
Rattlerattle
Sep 10, 2006 09:53 PM
Bobcat698
Apr 24, 2005 07:56 AM
ih1586
Jan 26, 2005 07:45 PM
atc250r
Aug 14, 2004 06:22 PM
