Differential questions?
Old Aug 31, 2006 | 09:51 PM
broncobilly's Avatar
All,
I am changing the differential fluid on my 93 W250. I know the rear Dana 70 takes 3 1/2 quarts (with friction modifier for the limited slip). Anyone know if there are torque ratings for the differential bolts (for the diff cover, D70)?
Also, how much differential fluid for the front Dana 60? Also, torque specs on the D60 differential bolts (for the diff cover)?
I know my 93 came with a factory installed limited slip in the rear Dana 70. I assume the front Dana 60 is an open carrier?
I appreciate all your help!
Old Aug 31, 2006 | 10:17 PM
whereswaldo250's Avatar
For the diff. cover they are 35ft lbs for dana 60 and 70 and in my dana 70 I pit 3.5 qts (with posi additive) and for my 60 I put 3.25 qts.
Old Aug 31, 2006 | 10:33 PM
Waldo,
Thanks much for the info!
Old Aug 31, 2006 | 10:38 PM
No Problem Just did mine not to long ago truck runs like a top
Old Sep 1, 2006 | 04:38 AM
Do not fill the diffs until the gear lube runs out the fill hole. Full is 3/8" to 1/2" below the fill hole. "Extra" gear lube often winds up on the brake shoes.
Old Sep 4, 2006 | 12:20 AM
Dave,
Thanks much!
Old Sep 4, 2006 | 05:23 PM
dpuckett's Avatar
I dont mean to start a war here, but even though my 93 FSM says to fill to 1/2 to 1in below the fill plug, I couldnt (now have a D80) hardly get 3.5qts in there without giong to the bottom of the fill hole. If one end up with oil on his brake shoes, he has issues elsewhere- maybe a vent plugged, or bad seal surface? I have close to 400K combined miles on these trucks, and have always filled them to the bottom of the hole with no issues.
Daniel
cwgtex
47
Aug 25, 2010 11:19 PM
Steven K
Apr 14, 2008 12:49 PM
DieselBD
Oct 16, 2007 08:33 PM
Mototrout
Oct 22, 2006 08:39 AM
Graeme
Oct 25, 2003 09:26 PM
