Differential oil change questions
Old Apr 9, 2008 | 01:58 PM
Steven K's Avatar
Time to change the front and rear differential oil.
So I don't need to put any sealant on the covers right?
What's the torque on the cover bolts?
Old Apr 9, 2008 | 02:50 PM
06RAM2500's Avatar
You can reuse the rubber ring. No gasket to fool with. Torque is around 20 ft/lbs.
Old Apr 14, 2008 | 09:56 AM
skalleknull's Avatar
i used a 3/8's butterfly impact, no leaks no problems, i went back in with Royal Purple 75-90. If i pulled alot i would of used 75-140 in the rear end. Also, the owners manual says the fill is 3/4 below the the bottom of the fill plug on the rear end and a 1/4 on the front end with a 1/4 plus or minus tolerance
Old Apr 14, 2008 | 12:02 PM
driver612's Avatar
how much
what is the capasity of the rear diff. on a 2500?????
driver612
Old Apr 14, 2008 | 12:49 PM
DBLR's Avatar
On my 06 it took 4 qt's after letting it drain for a few hours.
cwgtex
47
Aug 25, 2010 11:19 PM
DieselBD
Oct 16, 2007 08:33 PM
markm4
Jul 29, 2007 11:16 AM
Gordonville
14
Feb 27, 2004 07:16 PM
bkay
Oct 7, 2003 09:13 PM
