6 spd auto ? and observations
Old Apr 11, 2008 | 05:03 AM
ChrisM55's Avatar
After about 5K miles and about 1K towing my camp trailer I have a few observations and a couple of questions to see if mine might be acting up.
1. between 55-60 it HATES 6th gear!! On the way to Oregon I let it do its own thing for a good portion of the way. Ran right at 1500 RPM and had a horrible drone. Kinda sounded like my air compressor was coming on. As soon as it shifted up it was gone.
2. My milage up was about 9.8-10 and when I left it in 5th gear it went up to 10.4. locked in 5th my rpm was right about 1800 which seemed just right. I know I could have sped up but speed limit in Or. and Ca. is 55 and I can't afford tickets.
Now the question. Every once in a while it seems like it will forget what gear it is in and shift up and down a couple of times. It is always unloaded when this happens and seems to be around 57-60 mph. Also it will sometimes buck a few times at that same RPM. Has anyone ever had this happen??
Over all I love this new trans and the tow-haul is awsome!! It is like having 2 completly different tranny's! Add the ex. brake and WOW!!
Thanks
Chris
Old Apr 11, 2008 | 08:35 AM
motobuffy's Avatar
mine seems to like 1800rpm for cruising as well, both from a performance and mileage aspect. As to the erratic shifting, nothing like that here!
Old Apr 14, 2008 | 05:23 AM
Kman9090's Avatar
I was just reading out of curisoity but only 10mpg? Holy crap how do you afford that? Even the hemis will get 12mpg.
Old Apr 14, 2008 | 06:45 AM
GrandpasRam's Avatar
Not towing camper trailers through the mountains they won't. He was towing, and considering it was in the mountains, that is probably reasonable mileage.
ChrisM55 - 1500 RPM while towing OR empty is not what these trucks like for a cruising RPM, it seems too close to the starting range of the torque band. Especially when towing, they seem to like 1800 RPM much better for a cruise setting, and mine likes 1700 RPM running empty. As to the shifting, if you're trying to run right at the RPM where a shift up/down would occur, any auto trans will try to shift when the load changes like going from flat to uphill, etc. Keep the RPM up a bit and I'll bet you don't get the funny shift any more. This may sound couter-intuitive, but when towing a load the engine doesn't have to fuel as heavily to hold the speed at a little higher RPM (middle of the power band) as it does at lower RPM (lower part of power band); that's probably why you're mileage improved when you went back to 5th gear lock at that speed. When I was doing the towing break-in on mine, I noticed that it like 5th gear better and got better mileage with it at the 55 - 60 MPH range, and it didn't really like 6th (for cruising) until 65. Here in the Dallas Texas area where I live, there aren't many hills, so I was getting 12.9 MPG with the 5th wheel trailer in my sig. After the towing break-in, I've found that 70 - 72 MPH is where Mine likes to run in 6th, which is about 1750 RPM - at that setting I get about 11.5 MPG - that is about 1MPG better than my old '05 got doing the same. Considering you're in some mountains there 10.4 is very reasonable.
Old Apr 14, 2008 | 05:53 PM
Zarthur's Avatar
I shift mine in to 6 gear on the shifter, keeps it from hunting for it.
mxmike27
Nov 5, 2009 03:00 PM
pmtg
Sep 7, 2006 11:54 PM
raybob_99
Apr 4, 2006 04:31 PM
NCTURBOS
18
Oct 29, 2005 12:07 PM
