Differential oil change questions
Time to change the front and rear differential oil.
So I don't need to put any sealant on the covers right? What's the torque on the cover bolts? |
You can reuse the rubber ring. No gasket to fool with. Torque is around 20 ft/lbs.
i used a 3/8's butterfly impact, no leaks no problems, i went back in with Royal Purple 75-90. If i pulled alot i would of used 75-140 in the rear end. Also, the owners manual says the fill is 3/4 below the the bottom of the fill plug on the rear end and a 1/4 on the front end with a 1/4 plus or minus tolerance
how much
what is the capasity of the rear diff. on a 2500?????
driver612:o:o |
On my 06 it took 4 qt's after letting it drain for a few hours.
