Diaphram and afc star
Old Feb 22, 2006 | 12:27 PM
ruquik's Avatar
So i decided to go into the pump for more power. I turned the Star one maybe to click past 90 degrees CW. I rotated the the diaphram 120ish degrees CW.
So maybe i expected more but all i saw was a 1-2 lbs boost incresase, some smoke under load, and not much else.
Old Feb 22, 2006 | 12:32 PM
ruquik's Avatar
This was on the 93
Old Feb 22, 2006 | 12:36 PM
G1625S's Avatar
Sounds about right. Pull the cone right out of the pump so you can be sure you're setting the profile where you want it. For the most fueling, put the deepest part of the cone (least material) toward the headlights. My opinion on the starwheel is this: run it all the way down, then go drive it. If you like it, you're all set. If it smokes too much, too early, back it out in 90 to 120 degree increments till you're happy
Old Feb 22, 2006 | 05:03 PM
frostie's Avatar
Well you gained some with very little work. There is also the fuel screw that makes a bigger increase but takes a bit more work. The adjustments are free, big power starts to cost money, like turbo and nozzles.
Keep playing with it, its fun.
leper
May 12, 2008 12:42 AM
dan1stgen
Feb 4, 2008 01:02 PM
440forPOWER
Jun 15, 2006 11:04 PM
Tuckerdee
Mar 20, 2006 07:45 AM
plow
Jan 21, 2006 06:46 PM
