Lock up TC?
Lock up TC?
I think I have read most of the threads on torque converters. I have concluded that the stock converter in front of the A518 is like the 21cm exhaust housing. Nobody wants it, they are inefficient, and should never have been installed in the first place.
Now here are my questions.
How much better is the lock up torque converter compared to the 89% or 91% TC?
Is it worth the added expense and trouble?
A new flex plate and TC is in the works for my truck in the near future. I am looking for more power so the old TC will become toast by the end of this summer, if I ain't careful
. (and I'm not)
. (and I'm not)
. (and I'm not)
. (and I'm not)I don't think you can put a lock up convertor in your truck?? The differance between a stock 60-70% tc and a good 89% is night and day differance! Heck a tighter tc will be very close to a lock up at cruising rpm, but you will need serious hp to get 90% and tighter moving.
HTML Code:
Yuo can't get a lock up T/C for our trucks unless you have one of the rare late model '93 that had it from factory. The computer doesn't have a provision to know what to do with a lock up.
A tighter T/C is definatly a good upgrade. On mine it made the same difference as going from the stock turbo exhaust housing to a 16cm one.
From what I understand it is possilble to change the internal parts to make it a lockup trans, but I'm not going to get into that. I think Txs know's what parts to change. It was easier for me to buy one from a 94-95 truck.
I put a 47RH in mine in about one weekend.
-the bellhousing adaptor is thicker, about 1" to make room for the torque converter clutches. Any of them will do, 94-02 autos are the same.
-Starter off a 2nd gen for the above.
-Additional pin in the conector to control lockup. I use a switch, I control lockup and I think I do a much better job than the computer does anyway.
-Trans mount is going to need the slots lengthed to accomidate the 1" thicker bellhousing adaptor.
-Drives shafts MAY need to be shortened/lengthed. I didn't, the only thing I did was move the carrier bearing mount with 3/8 flat steel.
-Couple of other things I left out.
Is it worth the trouble? Yup.
Is it worth the expense? That an something you need to answer. I bought everything I needed for $900 used.
Computer?? We don't need no stinkin' computer!!
Mystery switches work quite well, or, if one is more creative a Hobbs switch, or, the more affluent will purchase a lockup controller.
How serious do I need to get? I am loosing 40 or more ponies with the stock TC. That would put me at 230 hp plus. There is still room to turn the fuel up, I think, now that the 16cm is installed I not running as hot exhaust as before. Has anyone lugged a diesel with an automatic?
Howdy,
I just posted this in a thread, but I'll add it here too...
Checkout this website for a way to automatically control your OD and Lock-up convertor with an oil pressure switch (or two) screwed into the side of the trans and a vacume switch.
I thought it was pretty slick...
http://www.transmissioncenter.net/alto_3.htm
Vinny
Vinny
xp8103
Jun 2, 2006 07:00 AM
mr T
21
Jun 1, 2005 08:48 AM
damon_achey
Jun 7, 2004 03:33 PM
