Dealing with twins bottom turbo's oil drain?
Old Apr 4, 2008 | 11:06 AM
MikeThomas's Avatar
Thats a funky title up there on this thread. Im planning out how to provide an oil return for a bottom turbo without punching the pan. It seems like even at its highest point the pan may have oil up to that point, making drainage difficult (?). Has anyone ever used some sort of scavenging pump to possibly pump the oil from both turbos back into the factory return port?
Old Apr 4, 2008 | 12:15 PM
pwrtripls1's Avatar
They have oil return pumps simular to what STS turbo kits use. They can be found for about $125 for just the pump and you will need relay, wire, fittings, check valve, ect. Is the bottom turbo's drain higher than the oil level in the pan?
Old Apr 4, 2008 | 04:50 PM
Free89W350's Avatar
I've read where guys just put a T in the existing drain and tied both turbos into that.
Old Apr 4, 2008 | 04:58 PM
Fred Swanson's Avatar
Mike, it's not that hard to put the drain into the pan, other than pulling the pan itself. If you can find a pan, I can show you exactly where to put it, and you can have it prebuilt for when your ready.
Old Apr 4, 2008 | 09:55 PM
stackx2's Avatar
pm dodgetrucker75he just tackled that problem 2 days ago he might have pics too
Old Apr 5, 2008 | 12:08 AM
Ilikebikes's Avatar
Just put it in the pan. A pump system is way too complicated for something that gravity will take care of for free.
And yes, I know it's a pain to pull the pan.
Edit: put it here. Not a single problem in maybe 5k miles so far? I haven't been paying attention as the miles on my truck rack up.
Old Apr 5, 2008 | 01:37 AM
MikeThomas's Avatar
What did it take to get the pan out?
Old Apr 5, 2008 | 01:49 AM
Alwaysworking's Avatar
alwaysonDTR
he probally had to lift the engine up as high as he could thats what my causin did to get his out but if you look in the background and see all the parts he might of had the engine out.
Old Apr 5, 2008 | 02:22 AM
Ilikebikes's Avatar
Unbolt the engine mounts, get out the engine hoist, lift it 'til the hoist starts making funny sounds, then pull it. Watch your hands around the mounts, though!
Old Apr 5, 2008 | 10:41 AM
MikeThomas's Avatar
Did you do it with the tranny in?
Old Apr 5, 2008 | 01:24 PM
Ilikebikes's Avatar
Yup, it's a tight fit but you can wedge it out.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
sammy340
Sep 22, 2005 08:30 PM
hotmopr
Feb 7, 2005 09:27 PM
