Dana m210
Old May 27, 2020 | 12:29 PM
avray's Avatar
Dana m210
Hi all,
my dealership tells me my front end is a Dana m210 wide front axle. Is this a Dana 60 or a 44? I have a 1992 w250 with a Cummins
Old May 27, 2020 | 12:33 PM
Never heard of a Dana M210.
The 100 or so, Cummins W-250s I have owned all came with a Dana 60 front axle.
Side note the '89-'91.0 auto trucks [and VERY few special ordered manual trucks] came with a Dana 61 so they could run the 3.07 gearing. Still basically a Dana 60F axle.
Old May 27, 2020 | 12:34 PM
I wouldn't trust the young bucks at the dealership to know what parts are actually in a 30 year old Dodge.
avray's Avatar
Sorry I meant spicer
Old May 27, 2020 | 12:36 PM
avray's Avatar
Is there a way to ID them by looking at a stamp or something?
Old May 27, 2020 | 12:39 PM
Dana Spicer...Same company.
Yes the Dana 60 front axle will have a 60F cast into the front pumpkin [pigs head, ETC]. Look around the edge of the diff. cover.
If it is the original axle you will find it is a Dana 60F.
Old May 27, 2020 | 12:50 PM
Fordzilla's Avatar
According to this from Spicer, the 210 indicates a 21,000 pound load capacity......Ben
Old May 27, 2020 | 01:01 PM
Yeah the dealership, might not know what they are talking about....Haha
avray's Avatar
Old May 27, 2020 | 01:02 PM
avray's Avatar
Here’s the diff. Still struggling to find it for sure
Old May 27, 2020 | 01:05 PM
Looks like a Dana 60F to me.
Scrape off the grease and grime and I will bet you will find a 60F cast into the outer edge of the diff housing just outside of the cover.
Old May 27, 2020 | 01:18 PM
The cast in 60F is to the lower left of the diff cover.
Old May 27, 2020 | 01:44 PM
u2slow's Avatar
Those 'young bucks' at Dodge weren't any better informed 20 years ago.
If your front GAWR is over 4000# or more, its a Dana 60... which all the 4wd cummins trucks came with.
A better 'tell' is the knuckles. The D44 uses balljoints and has a hook-shaped steering arm.
Old May 27, 2020 | 01:46 PM
Judging from the 2 studs that go into the axle on the passenger side leaf spring it is a Dana 60.
The Dana 44 uses two u bolts as the pumpkin is smaller
Old May 27, 2020 | 03:05 PM
u2slow's Avatar
My RC's D44 uses two studs also. GM D44's use two ubolts at the pumpkin.
