Dag-gum throttle cable !
Old Jan 22, 2011 | 07:00 PM
CFPoobah416's Avatar
My throttle cable gets stuck when i use the pedal no matter how far i push it down, and dont return, but if i pop the hood and do it manually with my hand its fine it goes down and returns with no problem ? ? ? anyone got any ideas like being frozen rusted etc . . . thanks
Old Jan 22, 2011 | 07:08 PM
ofcmarc's Avatar
Check the pivot on the pedal. Sounds like the pedal assembly may be sticking.
Old Jan 22, 2011 | 07:33 PM
ChrisLib's Avatar
I had the kickdown cable for the trans sieze on me and it gave similar symptoms. might want to take the cables off and see which one is binding.
Old Jan 22, 2011 | 09:04 PM
TIMMY22's Avatar
Let me tell you, these first gen cables are 95% better than the second gen cable set up.
Old Jan 22, 2011 | 10:10 PM
Santaclaus's Avatar
According to the 1993 manual you can disconnect the throttle cable at the foot pedal. That should tell you if it is the foot pedal or the cable. I don't know what year your truck is but I imagine they're all pretty much alike. Mike
Old Jan 23, 2011 | 03:10 AM
ebteckx's Avatar
i bet the sheathing is broken right at the pump end of the cable and its hanging up on the metal shroud... Thats what happened to mine anyway. id depress the throttle then it wouldnt return or sometimes it would hang up and i couldnt push it down!
Old Jan 23, 2011 | 01:52 PM
dodge350c's Avatar
I was helping him and it froze and we gave it some heat and as we were working the cable back and fourth it went ping when he went to hit it, So to kene dodge on monday. Dominic
3500_CTD
Oct 21, 2008 09:06 AM
BC847
NCDTR #18
Oct 7, 2008 08:38 PM
Kirk T
Sep 20, 2006 07:19 AM
MnTom
Dec 17, 2003 02:53 PM
hellotbone
Oct 7, 2003 06:54 AM
