D70 Mag-hytec question
Old Mar 20, 2009 | 01:10 PM
RowJ's Avatar
Ditto! My 02 should be same axle...no?
I have Pwr-Lok Dana 70 and most I get in her (top of dip stick) is just under 4.5 qts. w/ Mag Heynie Tec.
'RAMW350' - If memory serves, factory cover holds about 3 qts.... without tipping the rear to totally clean out the axles
RJ
Old Mar 20, 2009 | 05:28 PM
No. Your '02 should have a D80.
Old Mar 20, 2009 | 06:00 PM
freight train's Avatar
I have a factory clutch anti-spin carrier. I got about 5.25 qtrs of RP Maxgear in it/ wear inhibitor. I am just a hear over the top fill mark.
Old Mar 20, 2009 | 06:01 PM
Terraizer's Avatar
Don't auto 2nd gens have dana 70's and the standard trans 2nd gens are Dana 80's? What gear lube do you guys run with the MagHyTec covers i am rebuilding my 70 under my 93 and have purchased a MagHyTec cover for it.
Old Mar 21, 2009 | 10:17 AM
RowJ's Avatar
meant "ahould be the same D70 Axle".
I know I have a D70 Pwr-Lok (2nd Gen Automatic).
RJ
Old Mar 21, 2009 | 10:42 AM
I use Royal Purples Maxgear 75-90w with Trans-X. I know they say with RP you dont need to add a wear inhibator but I fell better safe than sorry. I really like RP products. With that said I just bought a NV4500 and I decided to use the Mopar (Castrol Syntorque). I know anything can fail but why test fate! New Venture prefers the Castrol. But for a rear I like the RP. They make different viscosities for the temp you are in!
Old Mar 21, 2009 | 10:53 AM
Ace's Avatar
Ace
How much in the way of metallic debris do you guys see on the dipstic when you pull it? I had a little fuzz on there, didn't seem to be excessive, but I hate seeing any at all. Just wonder if my rear is about to grenade from the abuse of a turned up pump, etc...
Old Mar 21, 2009 | 11:16 AM
RowJ's Avatar
Interesting question!
I have monitored this closely for the 6 yrs and found the results interesting.
I get black metalic 'mud' on my dipstick regularly. Gradual build up over 10-20,000 miles to point where it's pretty well covered with this mud at 20,000.
Also found that one hard day at track equals about 10,000 miles of mud on dipstick!! Heavy towing will produce somewhat similar results.
This mud is clutch face material and as long as it's not shinny metal shavings, it's perfectly normal......... or so I have been told by Dana experts.
I don't like seeing it either, BUT, the good news is loosing surface material from the clutches does not effect the performance of the Pwr-Loc. I have regularly tested mine (one wheel on wet grass and one on pavement) and lock up seems to be the same after 170,000 miles as it was early on.
If you find decreasing lock up performance, the concave plates in the Pwr-Loc can be rotated for more grab.
I pulled mine 2 yrs ago, to see how it looked. Clutch faces were scary looking so I replaced them.
Everything else in my 70 Pwr-Lok was in amazingly 'good as new' shape. It's a very strong gear setup!.........
But, as mentioned above, performance before and after new clutches felt no different, to me.
Note: I do use a high quality synthetic Gear Lube, and because I drag race, I do change fluid @ 20,000 miles. It's cheap insurance, IMHO.
RJ
Old Mar 21, 2009 | 11:45 AM
Ace's Avatar
Ace
Understand. My "fuzz" was shiny metallic!
Old Mar 21, 2009 | 12:37 PM
Trooperthorn's Avatar
Going back to the original capacity question. The fluid capacity will change with different ring gear sizes, different differential choices and different axle tube lengths. I have a 91.5 single wheel d70 and a 93 dually d70 on my shop floor right now. The dually housing is two inches wider backing plate to backing plate than the single. all of these variable make a difference on actual capacity. The Mag-hytec folks probably took a high average capacity figure to include in their speck. A deep look in the fine print may include a disclaimer about actual capacities may vary based on individual configuration.
I had two cents to spare. Thought I'd share.
Old Mar 21, 2009 | 04:12 PM
I had it in for a couple miles and noticed alittle black fuzz on there! I noticed an incredable amount on the this debris on the factory cover magnet. The funny thing is I probably have 20k on the oil. I absolutly love the dipstick magnet!!!!
RJ285
May 7, 2011 09:52 PM
pulpwood007
May 23, 2010 10:00 PM
BAJA MAN
May 24, 2009 12:58 PM
bry@n
13
Dec 28, 2007 08:26 PM
kry226
14
Jan 22, 2005 10:36 AM
