Custom Intake Cross-over Pipe ??
I just saw BGilbert's add for a three-inch intake adapter and it got me to thinking.
All other things remaining the same, would I lower my EGTs by building a new intake cross-over pipe that terminated in a three-inch intake horn pointing straight up??
If I understood correctly, the horn in BGilbert's add can be oriented to point straight up; is this correct??
We are talking about my non-I/C 89 engine.
If the intake horn pointed forward, or aft, it would necessitate two 90* elbows at the horn, thereby losing quite a bit of any advantage gained.
Thanks.
Thanks.
One can point forward or back, the other to either side. I dont know about lowering egts much but it would be a benefit over the n/i crossover. Im building a 2 1/2" crossover from exhaust tubing as we speak so that I can upgrade the turbo.
That means it's time for a body-lift.
All in all, the two inch body-lift on my Ford made every other thing I have ever had to do on it since a WHOLE lot easier.
It is unreal how much clearance around the engine/bell-housing/transmission a mere two inches can make.
The best way that is done is to weld a bung onto the tube. Tubing is so thing that theres really no way to get more than maybe 1 or 2 pitches of thread with a tap. Take some 1x2x3/8" strap or something similar, tap a hole in that and then weld all the way around it to seal it to the tube, that'll do it.
