CTD newbie... stock rear lift blocks?
Old May 13, 2006 | 10:12 PM
Ilikebikes's Avatar
Hey guys. I'm new here (obviously) and you guys have an awesome forum over here. It reminds me a lot of the pirate 4x4 forums... lots of helpful posts! Anyway, I just bought a 93 4x4 ext cab LE CTD. I was checking out the rear end and I saw HUGE lift blocks, probably 5-6". To tell you the truth they look kinda scary. So I came here and searched, and found that the 91.5 and up blocks are taller than the older ones? Are these huge blocks stock? They almost look like it, since there is the bumpstop built into the block itself. Wouldn't this cause axle wrap problems? I come from the toyota 4x4 crawler area, so running blocks this big on a crawler would be insane, so maybe that was why I was so suprised.
Thanks! Really loving this forum so far!
Old May 14, 2006 | 02:12 AM
fjkfta's Avatar
yep thats stock got a 93 too. add man those are some big blocks down there lol
Old May 14, 2006 | 04:54 AM
Boatnik's Avatar
MY 92 is the same way. Huge lift blocks in the rear.
Old May 14, 2006 | 08:34 AM
But without the hostility towards newbies and R-rated language.
Old May 14, 2006 | 10:39 AM
cLAYH's Avatar
If you look at your spring pack they are twice as thick as what you would find on a crwaler. They are designed NOT to flex but for weight carrying ability. I have never noticed any axle wrap on my '92.
Old May 14, 2006 | 10:53 PM
highwayrepair's Avatar
axle wrap
Wow, my 92 4X4 has tons of axle wrap unloaded in the dirt. with a trailer on it, or on pavement its fine though. Im planning on buying huge lift leafs from superlift( forgot exact height, but they were about 7-9") and removing the 6" or so lift block from the rear end, that way i can gain a bit of lift and get rid of those blocks, I'll be accompanying that with a set fo either 2 or 4 " lift springs up front, havent decided yet. I dont have to have to do ANY drivetrain modifications and some say you do, some say you dont with the 4" springs. I wouldn't worry about them too much, their stock, Im only getting rid of due to my usage of the truck.
Branden
Old May 16, 2006 | 09:22 AM
Ace's Avatar
Ace
That's what the PO did with my '91. Seems like a pretty good idea. Skyjackers. Lifted the rear about 2" and front 1". No blocks, better stance, smoother ride and looks almost stock.
Old May 16, 2006 | 12:39 PM
DISLSMOKE's Avatar
[QUOTE= Im planning on buying huge lift leafs from superlift[/QUOTE]
You may want to look at skyjacker, quality is a little better than superlift. From what I have read skyjacker is very stout for 3/4 ton trucks..(just my 2 cents) I'm running skyjacker on my CJ-7. Truck will get 2" skys in the front when I drive over a pot of gold.
Old May 16, 2006 | 12:54 PM
G1625S's Avatar
Just to add some fuel: If your leaf springs are wore out, you WILL experience an absurd amount of axle wrap. See my new thread ''holy spring wrap, batman!''
06CTDforAU
Oct 16, 2007 09:34 PM
Katmandu
Jan 16, 2006 08:30 AM
PZM123
Nov 23, 2004 03:16 PM
