CRUISE CONTROLE
CRUISE CONTROLE
I need a little help, my cruise controle stoped working. Last week when I would try to set it It was hard to get it to pick up but once I got it set it was ok. now it don't want to work at all.THANKS.
Re:CRUISE CONTROLE
I am not familiar with the complete troubleshooting sequence but with the help of the DTR I managed to fix mine which wasn't working at all. Check your vacuum lines to ensure you have no leaks to the vacuum pod/actuator. You must ensure you are closing the circuit through the steering column contact ring? as well as the 'set' and 'on-off' switch on the wheel. Through the use of a multi-meter I had determined my set switch had worn out and a micro switch from an electrical outlet did the trick for me. <br><br>Good luck.
Re:CRUISE CONTROLE
I’m not sure if this will help but under the hood where the throttle cable connects to the speed control there is a plastic adjuster at the end of the cable ( I think it’s the throttle cable I don’t have the chance to look right now). Sometimes the plastic will slide to far out of the clip and you just need to reset the cable back which will eat up the slack. Hope this helps.
trophystock
07-06-2006 06:28 PM
03quadduallyho
03-24-2003 05:34 PM
