Cruise control fix
Old Jan 29, 2012 | 07:00 PM
olgrey93's Avatar
Cruise control fix
I have a 93 d 350 le and the cruise doesn't work. Any suggestions for a fix? Thanks in advance
Old Jan 29, 2012 | 07:25 PM
dieselluvr's Avatar
does your horn work?
Old Jan 29, 2012 | 07:38 PM
olgrey93's Avatar
Yes the horn does work
Old Jan 29, 2012 | 08:13 PM
bobva's Avatar
Brake pedal
Old Jan 29, 2012 | 08:43 PM
Onemoparnut's Avatar
Does the speedometer work?
Old Jan 29, 2012 | 08:54 PM
olgrey93's Avatar
Brk pedal yes and speedo and odometer no
Old Jan 29, 2012 | 09:24 PM
You have to fix the speedo for the cruise to work. Check the plug on the trans for the vss. Clean the connection really good and once the speedo works then you can trouble shoot the cruise. If the computer don't see a signal from the vss it don't know how fast you are going to start with.
Old Jan 29, 2012 | 09:41 PM
olgrey93's Avatar
I've replaced the vss and still didn't work. I think it's the internal gears. But I have a garmin that tells the speed so I haven't gone any farther with it. Plus I've heard it's pretty pricy
Old Jan 29, 2012 | 09:46 PM
Until the speedo is fixed the cruise will not work.
Old Jan 30, 2012 | 09:03 PM
dieselluvr's Avatar
IF it's the speedo gear (which I doubt) they can be had at junk yards or a $17 at mancini racing maybe a few bucks more at the dealership.
Rattletrap1
Sep 24, 2006 04:44 PM
Mike D
13
Sep 19, 2005 09:26 AM
Goodys1ton
Aug 28, 2005 01:25 PM
TexasDiesel
Dec 27, 2002 10:47 AM
