Cruise control fix for Mad ECM.
Old Aug 26, 2005 | 08:44 AM
Mike D's Avatar
I don't know if anyone has the same problem I've been having when appling cruise control. When I hit the set button the truck would sound like it was floored then settle down, but the cruise control was not steady once set.
I had read about installing some kind of adjustable valve inline with control module, but I could never find one.
My solution was to put a spray tube (little red tube) from a aerosol can inside the vacuum tube going to the cruise control module under the drive side battery. The tube fit perfectly inside the vacuum line, I left it a little long so if I ever wanted to remove it I could still take it out. The small inside diameter of the spray tube seems to be just right. Cruise control works great now.
I installed the tube up by the T connection on the firewall.
I thought I would pass this along in case anyone else was having the same problem.
Old Aug 26, 2005 | 09:38 AM
Marco's Avatar
Great idea!
Now that's a GREAT idea! I'm in your same boat. Never been able to find such a small needle valve. I'll give it a try and report back!
Thanks!
Marco
Old Aug 26, 2005 | 09:47 AM
infidel's Avatar
Excellent idea!
I've done this mod to several trucks but never thought of the spray tubes.
I did it the hard way with a piece of solid round plastic that fit inside the vacuum line that I pushed a hot needle though.
Came close to your idea though by using the insulation off of some electrical wire, hole was too big though.
Old Aug 26, 2005 | 10:08 AM
Mike D's Avatar
Originally posted by infidel
Excellent idea!
I was going to do almost the same thing. I was down in the basement looking for something to fit the line and poke a small hole in it. I looked down on my work bench and saw the tube. It was pretty eerie, I knew it would work before even trying it, ( I guess that's what you call the light bulb effect) LOL! It almost seemed too simple if you know what I mean.
Old Aug 26, 2005 | 10:16 AM
Mike D's Avatar
While we are on the subject of the Mad ECM. Does anyone notice a strong surge backing out of the pedal at WOT. The best way to discribe it, is when you go wide open then you let out of the pedal at about half way the truck surges a head for a moment like it still WOT. If you have had this happen you'll no what I mean.
Old Aug 26, 2005 | 10:24 AM
Marco's Avatar
Already tried it. It WORKS!!!!
If there was a contest for the smartest and less expensive fix, Mike D would be the winner!
Very well done!
Thanks!
Marco
Old Aug 26, 2005 | 10:26 AM
Marco's Avatar
Mike,
lookie here :http://www.turbodieselregister.com/f...d.php?t=136611
You might find a few answeres in this thread.
Marco
Old Aug 26, 2005 | 10:27 AM
Mike D's Avatar
Thanks Marco! Hopefully, everyone who has had this problem will benefit. Glad I could help.
Old Aug 26, 2005 | 10:48 AM
Mike D's Avatar
Marco, I read the thread you provided, seems logical. Thanks! I just have to have a talk with my right foot now!
Old Aug 26, 2005 | 07:06 PM
2500CTD's Avatar
As a way to help increase MPG I used a small orifice, from a Didge 2.2L Turbo car. The orfices is usually in the waste gate acutator line. Actually going back and looking they are in a lot of the solenoids on those cars. Come in different sizes too. It slowed the response of my cruise down, and I dont have a MAD yet. Just another idea. I didn't think of the spray tube, since I also play with these turbo cars, I just waded through my spare parts till I found something.
Old Aug 27, 2005 | 06:03 PM
rebal's Avatar
hey I dont want to high jack this thread but did any of you loose a gage in the install? i just installed the mad ecm and now i have no oil pressure gage
Old Aug 27, 2005 | 08:12 PM
HOHN's Avatar
This is a good cruise control fix, but it won't work for those of us with electronic cruise controls.
My 02 6-speed has the electronic CC, and thus no vacuum methods to cheat
Old Aug 28, 2005 | 02:05 AM
2500CTD's Avatar
Why autos are better!
Old Sep 19, 2005 | 09:26 AM
Beast2B's Avatar
Autos are better...
I only get an INKLING of that when i want to drink coffee and shift at the same time. All I have to do is look at the receipt for my clutch and compare that to the cost of the auto upgrades... YIKES!!
OK, and when i want to use my cruise control...
olgrey93
Jan 30, 2012 09:03 PM
mouseguy
Aug 25, 2009 07:15 AM
Rattletrap1
Sep 24, 2006 04:44 PM
Goodys1ton
Aug 28, 2005 01:25 PM
