cruching noise in steering column
Old Aug 5, 2009 | 12:59 PM
RWells's Avatar
Hello everybody,I got a crunching noise in steering column sounds like its coming from the firewall area of the column. steering gets stiff and then crunches and gets easy again and so on is there bearing in that part of the column, has anybody had this problem. Thanks ahead of time for any info.
Old Aug 5, 2009 | 01:06 PM
apwatson50's Avatar
clock spring, bet your horn and CC don't work anymore?
Old Aug 5, 2009 | 01:14 PM
RWells's Avatar
cc and horn work fine noise is coming from around the firewall .
Old Aug 5, 2009 | 02:16 PM
apwatson50's Avatar
Crunch it a few more times, they'll stop working.
Or it could be the inner column coming apart from the outer column.
Old Aug 5, 2009 | 02:45 PM
archer39's Avatar
i would bet the clock spring also. It is not something that you want to drive around with busted. It will bind your steering not allowing you to move the wheel.
Old Aug 5, 2009 | 07:04 PM
Trebor's Avatar
Check your rag joint and its flange mounting where the steering comes through the firewall. Corrosion and fatigue may be setting in.
Old Aug 5, 2009 | 07:59 PM
jimbo486's Avatar
time for a borgeson steering shaft...? i mean, what the heck, if it is corroding and getting fatigued like trebor says, it's an upgrade that's well worth the time and money.
M1AM14SPUR
Jan 8, 2012 06:17 PM
dieselcarpenter
Jun 11, 2011 06:03 PM
mstep3
Dec 27, 2009 02:23 PM
MikeyB
Apr 8, 2004 05:21 PM
scottrod
Dec 13, 2002 03:06 PM
