Crew Cab Project has Started
Old Dec 18, 2011 | 03:59 PM
  #61
brcron007's Avatar
Hi DJTurbo,
You win ! It does look better this way and it is centered a little better to boot.
Thanks for pointing it out.
Old Dec 18, 2011 | 10:58 PM
  #62
DJ Turbo.'s Avatar
Originally Posted by brcron007
Hi DJTurbo,
Np man it just looked better that way and flowes with the trucks lines
Old Dec 20, 2011 | 04:28 PM
  #63
CE_TX's Avatar
What is the cargo/brake light off of?
Old Dec 21, 2011 | 08:42 PM
  #64
brcron007's Avatar
Well......Some may get mad !!! But the cargo light brake lite combo is for a 2011 Chvrolet Colorado.
Old Dec 21, 2011 | 09:24 PM
  #65
brcron007's Avatar
Well I had to go back to the drawing board for the rear section removable roof panel. The 2 front skins for the rear just didnt have the correct contour to work.
So this is what I did. I made a flange.
This flange lip will be attached to the back side of the skin to hold the kin in place. I attached it to the outside first so all the screw holes would line up perfectly befor any cutting was done.
Old Dec 21, 2011 | 09:35 PM
  #66
brcron007's Avatar
Next I cut the rear skin out. Carefully of course. No surprise I found another moisture absorbing fiberboard under the skin. Nice of dodge huh ???
Now the boards out you can see our friend the surface rust monster !!!
Here's the skin I cut out and the flange.
Here's the backside of the skin showning more of the surface rust monster !!!!!
Now I can sleep at night knowing I've addressed the commy rust pig that was eating at my truck.
Now I'll be able to add dynamatt and some jute padding to stop any oil canning as well.
Hope you all enjoyed my little roof panel making cutting adventure ??
Old Dec 21, 2011 | 10:58 PM
  #67
simplysmn's Avatar
Nice write up Bud funny thing thou I just cut a 81 crewcab up and it didn't have anything in roof maybe a west coast thing ? not having it ?
Old Dec 22, 2011 | 01:07 AM
  #68
DJ Turbo.'s Avatar
Who cares it looks good thats all that matters we put ford mags on our trucks so if anyone gets mad then they are way to much of a *I'll leave it to your imagination* and I thought I recognized the gm style of backup light I was gonna ask but hadn't yet thanks for the answer haha
Old Dec 22, 2011 | 08:01 AM
  #69
brcron007's Avatar
Thanks DJ.
She is a west coast truck. 27 years in Phoenix, Arizona 1 owner. This minor surface rust is from condensation, I'm sure.
Old Dec 29, 2011 | 01:44 PM
  #70
Jungle's Avatar
Ron,
You are doing a AWESOME job on your crew cab!!!
Jim
Old Dec 29, 2011 | 03:26 PM
  #71
slatemd's Avatar
I'm drooling............
Old Dec 29, 2011 | 05:49 PM
  #72
brcron007's Avatar
Thanks Guys. I'll be posting todays progress pics in just a few. Have to resize em.
Old Dec 29, 2011 | 07:15 PM
  #73
brcron007's Avatar
Here's a pic showing the removable panel sectin of the roof.
All of the bare metal on the whole cab has been treated with the metal prep pickle X 20 so it won't rust. Every nook and cranny.
Here's the passenger side cowl where it cracked. It's hard to see but it cracked at the weld.
Here you cab see the crack better after I ground down the factory weld.
My batteries died. But I did reweld the factory welds before I added the reinforcement metal patch.
A little hard to grind it down perfect. But I think it turned out pretty good. Shouldn't crack again. Fingers crossed.
Old Dec 29, 2011 | 07:36 PM
  #74
brcron007's Avatar
Here's the driver's side cowl area. This factory weld hadn't cracked at all.
Here's the reinforcement patch I cut out.
Here it is mostly welded in.
Here it is cleaned up.
She is now completely officially ready for primer. The cab is all sanded, repaired and cleaned. Took awhile but I wanted everything perfect. A little nutty but I didn't want to have to do it again for along time.
Old Dec 29, 2011 | 08:33 PM
  #75
DJ Turbo.'s Avatar
Thanks DJ.
Can't wait to see the finished project and I just wish I could get started on mine!
