Cracked NP205
Old Oct 17, 2013 | 02:36 PM
Originally Posted by bannerd
I'm thinking my idler gear will work fine the more I look and think about it. I'm just dreading putting this think back together.. the fork pins are a pita.
Easiest way to do the roll pin in the forks is to start the roll pin in the fork first. Then get them in place and slide the shaft through. Get your gears and clusters installed. Then use a small piece of wire, coat hanger works well, down the center of the roll pin to line up with the hole in the shift rail. Once it's all basically lined up remove the wire and then gently start tapping it into place. Was not that difficult....little trial and error, but not too bad.
jabcon
33
Mar 18, 2018 04:32 PM
klx650a2
Apr 20, 2009 05:25 PM
97catintenn
Feb 11, 2005 01:47 PM
WVPANHANDLER
Feb 1, 2003 08:23 PM
1stGenBikeHauler
Jan 25, 2003 12:31 PM
