A couple of quick questions
Old May 17, 2008 | 03:48 PM
91.5 beater's Avatar
Smile A couple of quick questions
My cruise control wont work but in the past few weeks it would set and hold speed for about 5 seconds and then it would shut off, and now it wont do anything, any ideas?
Also with the price of diesel going up i was wondering if a 50/50 mix of ATF and diesel would be ok, the past owner ran that mix for a long time and assures me that it will be good, What do you all think of that?
Also how many of you all have aftermarket tranny coolers, can you all post pictures, also what kind of improvment does it give, Do you all reccommend doing this?
Old May 17, 2008 | 04:10 PM
bradshaw106's Avatar
what, do you have a secret stash of atf? i didn't think that stuff was cheap especially in the form of gallons
Old May 17, 2008 | 04:12 PM
No i would get it used from some buddies of mine in 55 gallon drums for free
Old May 17, 2008 | 07:59 PM
Horn work? Crunching noises from the steering column?
The 50/50 mix is a little heavy unless you work the truck pretty hard. I'd keep it down around 20%. Make sure you filter it first.
Old May 17, 2008 | 08:59 PM
No there is no noises coming from the steering colm, What do you mean by work it pretty hard?
Old May 18, 2008 | 05:22 AM
KRB's Avatar
KRB
I thought used AT was a unles filtered REALLY good to remove the metal debris.
A properly sized AT cooler will make a difference, especially if you tow. It keeps my tranny in the safe range.
Do a search on the cooler for pics & details. Same on fuel mixtures, there's been a lot of arguments - I mean discussion of what to mix and how much.
Old May 18, 2008 | 01:06 PM
Dean Snow's Avatar
Well with the stock cooler my transmission would run anywhere from 190-220 without towing. Then the transmission blew up!
Got the transmission redone with a nice sized transmission cooler and now i stay in the range of 145 on the transmission
Old May 18, 2008 | 06:06 PM
Does the horn work?
If you run a lot of waste oil in a truck that runs around empty all the time, it tends to cause a lot of deposits on the injectors.
Old May 18, 2008 | 06:42 PM
racerdude_9's Avatar
this is a discussion that some dtr guys are having about the topic, used motor oil, atf thats sorta stuff.
Old May 18, 2008 | 06:43 PM
sorry heres the link.
<https://www.dieseltruckresource.com/forums/showthread.php?t=199542>
Old May 18, 2008 | 06:46 PM
Free89W350's Avatar
here this should make it easier to open
https://www.dieseltruckresource.com/...d.php?t=199542
Old May 18, 2008 | 07:15 PM
1 grumpy's Avatar
had the same problem with my dodge found out it was the brake sensor at the brake peddle kept on slipping off welded a little tab where the sensor touches the peddle and haven't had a problem since..Hope the help's
Old May 18, 2008 | 07:28 PM
what do u need cruise control for anyways. just put a brick on the floor. it only goes 140 down hill lol. but then again i guess that and expensive ticket at 40 over. lol.
Old May 19, 2008 | 06:05 PM
My truck is always above 3/4 tank so it is never totally empty when i put the used motor oil in it. Ill check on that brake sensor, my horn does work
Old May 19, 2008 | 08:00 PM
77machomopar's Avatar
I think when wanna means empty he means not loaded in the bed or a trailer.
