Cooling/Overheating questions
Old Sep 21, 2007 | 05:33 PM
TJE's Avatar
TJE
Unhappy Cooling/Overheating questions
Hello everyone, I have some cooling questions. My truck the one in my sig. has started to get warmer than it has in the past. The temp guage rides about the middle with my small trailer in tow. I'm half afraid to pull my 5th wheel! My question is what is the answer?
I have a new radiator, new hoses, new Cummins thermostat, and it still gets a warm as ever before. Again, what is the answer to this problem?
TIA: Tony
Old Sep 21, 2007 | 05:35 PM
92ctd's Avatar
just a thought is your radiator clean? i took mine out and cleaned it and it made a difference in running temp.
either way, good luck
edit: how about your air filter? is that clean
Old Sep 21, 2007 | 05:43 PM
TJE's Avatar
TJE
The radiator should be clean as it is new. The air filter is a bad K&N that might need cleaning. Thanks, Tony
Old Sep 21, 2007 | 06:33 PM
2stroke's Avatar
put a known good guage on it and see what it reads..old dodge guages arnt known or thier accuracy.
Old Sep 22, 2007 | 07:16 AM
The middle is where it's supposed to run.
Old Sep 22, 2007 | 08:18 AM
TJE's Avatar
TJE
Well thanks for enlightening me! If that is where it is supposed to run, then no problem. I just thought, ( I know I'm not supposed to think ) since it used to run near the first inside mark that's where it should be. Thanks, for the help, Tony
Old Sep 22, 2007 | 12:09 PM
It sounds to me like the old thermostat was letting it run a little cold. As long as it's not past the 5:00 position it's OK.
Old Sep 22, 2007 | 02:10 PM
TJE's Avatar
TJE
Most of the time it is at 6:00. It might get to five if I have it WOT.
Thanks, Tony
Old Sep 22, 2007 | 03:49 PM
leper's Avatar
Your fan clutch may be going out. Just something else you can check.
btoops
Jul 28, 2011 09:09 PM
jlbrown
Mar 12, 2008 05:42 PM
Dan Marino
16
Jun 8, 2007 10:21 PM
mopar2ya
Apr 1, 2004 06:42 AM
apache
Feb 23, 2004 07:28 AM
