coolant bleeder pics
Old Dec 29, 2008 | 11:36 AM
NO_SPRK's Avatar
coolant bleeder upgrade
so recently i have been dealing with some cooling problems and one thing i realised is i HATE that coolant bleeder. slamming a 5/8 12-point socket on and prying it off is a pain in the *** and having to make sure it seals everytime is also a hassle.
today i put a new thermostat in my truck and did a coolant flush so i decided to fix my problem and headed to my local home improvement store. i was originaly looking for the same large fitting but with a small standard hex head plug to thread in until i saw this. if this works out well then i will leave it otherwise i will get that hex head plug. i liked the compressor drain valve because i dont have to worry about sealing it everytime i take it on or off but i am a little worried about vibration so im going to keep a eye on it for a little while. with the pressure of the water it shouldn't open even with vibration because its a reverse thread and when it opens it screws down.
the size on the big fitting is 1/2inch pipe thread and the bleeder is 1/8inch pipe thread. i did have to grind the bleeder down a tiny bit on each side to clear the engine pull mount. even if i change the bleeder to the hex head bolt im still happy with the results and im glad to get rid of that old junker.
Old Dec 29, 2008 | 06:10 PM
BearKiller's Avatar
That is some good thinking.
The plugs in all of my fleet required a 3/8" square-drive.
I have the mechanical temperature sender in that port, so I can't use your idea.
What I am going to try is to install one of those garden-hose flushing ports, spliced into the heater-hose, for air-bleeding purposes.
If I don't get every last bit of air bled from the coolant system, the mechanical gauge will not read.
Usually, it takes numerous bleedings, a day apart, to finally purge the air.
MKELLY
Apr 5, 2006 09:43 PM
Dave88LX
Nov 19, 2005 02:55 PM
billhunt
Oct 9, 2005 09:57 AM
Iron City
Jul 26, 2005 07:03 AM
eng208
Nov 11, 2004 08:18 PM
