Continuous white smoke and missing/popping
Old Nov 18, 2017 | 12:36 PM
LCormany's Avatar
Hi there! This is my first post on here, so forgive me if I doing this wrong. Anyways I have been lurking for a while trying to solve my issue but cannot find a thread that is similar to my problem.
So here we go, I bought new injectors for it a little bit ago and just now got around to installing them. I had installed them with the thinnest washer that came with the kit. Also I went through the injection pump while I was doing this because it needed new seals, mind you I was careful to pin the pump and not move anything else to prevent messing up the timing of the pump.
After all that was done I took for a test drive around the block to see if was running better and if I had alleviated any of the problems that I had before, which I didn't. LOL The truck was running alright but about a mile down the road, I went to pull away from a stop sign and it started belching white smoke. I mean a lot. Anyways I pulled over and shut it down. Started it back up and drove it back to the shop, while continuing with the white smoke and popping/missing. The Injectors I bought are rebuilds and I am not sure if that has anything to do with it or if I messed up somewhere in the pump. Any advice would be super helpful. I am college kid still learning about these trucks and trying to wrench on a college budget. I grew up on a farm so I know how to turn a wrench too. Thanks in advance!
Old Nov 19, 2017 | 03:14 AM
KRB's Avatar
KRB
Welcome to the Forum!
I'm afraid I can't help much in the injector/pump department but can tell you that the white smoke is probably raw unburned fuel, for whatever reason.
It might be helpful to also know what the truck was doing before you replaced the injectors and rebuilt the pump? Was it running the same or different?
Those that know will chime in.
Old Nov 19, 2017 | 06:48 AM
I would guess it is a timing issue.
I usually see white smoke when my trucks are not timed enough, or I have a restriction in fuel delivery, like air in the fuel lines or a gelling fuel filter.
Did the key away in the injection pump stay in place, or did the timing slip at that stop light?
Did all the injector lines go back on in the right order?
Maybe just a few things to check.
Old Nov 19, 2017 | 10:53 AM
bigragu's Avatar
You may have a pintle in one or more of the injectors stuck, therefore flooding the combustion chamber with fuel. I recently purchased new, quality injectors and #4 had a debris in it that held that pintle open, and I got all the symptoms you're describing. How I knew something was wrong was I slowly cracked open each injector nut and saw high pressure fuel spraying out, and the idle would change. So, for your knowledge that's a good thing. Then when I got to #4, it was not spraying fuel, but instead foaming air bubbles, and no idle change.
The vendor I bought it from replaced the injector like way quick, with no questions asked whatsoever
Old Nov 20, 2017 | 07:44 AM
Angry Johnny's Avatar
Not knowing what problems you had before is a hindrance to diagnosing problem now. However I will say that it looks like something you did. First thing I would do is put the original injectors back in it. If that fixes it then you know where the problem is. If it doesn't I would pull the pump and check that the woodruff key didn't slip out.
Old Nov 21, 2017 | 03:23 PM
MrFusion's Avatar
Did you remove the pump from the engine?
John93CTD
Feb 8, 2013 07:41 AM
bcfitzsimons
17
Jul 13, 2007 06:49 PM
smokethestroke
Mar 22, 2006 09:17 PM
runamuk
26
Feb 25, 2006 03:24 AM
cumminsdriver635
Mar 6, 2005 10:54 AM
