Compression ?
Compression ?
Does anyone know what the normal compression in our engines should be? I just did the compression test and the all had between 350 and 375 pounds. Am pulling the head now so wish me luck.
Stomp
Well after spending all night reading through the search forums on a few sites, I've come to the conclusion that there must not be a normal compression. I have seen them as high as 525, and as low as 260. Mine probably would not be as high as most due to the 20 over head gasket. From what I have read, as long as the cylinders are within 20% of each other the cylinders are ok.
Commatoze
09-30-2004 12:53 PM
