coilover CTD?
Old Aug 26, 2007 | 05:59 PM
MoPowa's Avatar
coilover CTD?
Im surprised I haven't seen anyone do a coilover system to a 1st gen diesel. I've looked everywhere and cant find any info on it. Besides the links, it doesn't seem like it would be all that hard.
Anyone seen it done? I saved myself a bunch of money by buying old, I figure I may as well spend a bit on my 92 ctd 4x4.
Old Aug 26, 2007 | 06:42 PM
flyingd's Avatar
What is a coil over system
I hope I am not the only one who doesn't know what that is.
Old Aug 26, 2007 | 07:01 PM
marksmith's Avatar
I dont think making upper shock mounts beefy enough for coil-overs would be worth it IMHO.
Your looking @ 4K lbs on the front axle.
Then there is the 4 link....
It would ride however you needed it to though.
Old Aug 26, 2007 | 07:26 PM
LOGAN's Avatar
Muted User
Build a long arm 4 link setup, they sell them as bolt on kits all day long for 2nd Gen trucks, a set of long travel king coilovers, you wouldn't use the stock mounts, build a set of hoops and connect them with an engine cage, you would either swap to full hydraulic or heimed crossover steering.
coilover: http://www.desertrides.com/reference...s/coilover.jpg
4 link: http://www.setstr8.com/images/ford97kit.jpg
engine cage: http://www.camburg.com/images/Ranger...ine%20cage.jpg
I'm sure Don Thuren could built you a nice little setup, www.thurenfabrication.com
Old Aug 26, 2007 | 10:20 PM
MoPowa's Avatar
yeah I dont imagine it would be too hard. I could just build a bolt on link system to keep it legal, im not sure what the laws are here around canada but im suure i could get away with it. The most expensive part would be the coilovers, and driveshafts. I plan on keeping this truck a while, may as well build it to suit.
Old Aug 26, 2007 | 10:30 PM
dan1stgen's Avatar
sounds sweet you could go as high as you want maybe 49" IROKs and some cv joints on the front drive shaft clock your t-case and youd be set
Old Aug 26, 2007 | 10:48 PM
MoPowa's Avatar
ahaha. I dunno about 49'' tires.......thats pretty big. I was thinking more along the lings of some 37'' toyo's. Do some fender trimming then i'd be set
Old Aug 27, 2007 | 02:40 AM
Murf's Avatar
I been thinkin' the same thing Mopowa.
It's most definitely do-able. Just having access to the torch/welder/bender/plasma cutter/time to do it/etc. Is what's stopping me.
That nerdbag cancuck Ian Johnson got me thinkin' about it when he/they did a coilover for their Suburban Gorilla project. They used junkyard upper bucket seats and from what I remember fabbed and/or pieced the rest of it.
Tell ya what, you do a write up that is "sticky" worthy (detailed pics included) and I'll be the first to follow!
Old Aug 27, 2007 | 08:25 AM
leper's Avatar
I have been thinking about an airbag system for my truck and beefing up the front top mounts would be the only hard part.
Old Aug 27, 2007 | 10:51 AM
LOGAN's Avatar
Muted User
who would guess that you was from florida with that comment........
Old Aug 27, 2007 | 06:20 PM
frmll300's Avatar
Go drive a 2nd gen like mine ( everything new and you still don't know where it wants to go next)and you'll think about just adding airbags to the
front of your first gen and smooth out the ride.
Old Aug 27, 2007 | 10:55 PM
LOGAN's Avatar
Muted User
sounds like you need an alignment if its wandering that bad or something isnt right.
Old Aug 27, 2007 | 11:49 PM
MoPowa's Avatar
Yeah i was thinking about finding a wrecked 2nd gen diesel and cutting the buckets out, and using lifted coils. Build my own beefy links and pitman arm, and i'd be in business. I was thinkin about airbags as well, but it just seems to me a coil would be easier to deal with........though the on board air would be nice. Im going to start collecting some parts, when i get some time to take the truck off the road i'll start building and snappin pics for you all.
What kind of heim joints do you all think i should look into? The front will have to be pretty beefy.
Old Aug 28, 2007 | 01:32 AM
KRB's Avatar
KRB
Bags up front is the way I'd like to go. Several here have cobbled their own together. Just seems like a good way to handle the extra weight of the CTD, especially when yours leaves have the frown . Bags are relatively cheap now, just need to build and mount the brackets...
Old Aug 28, 2007 | 07:39 AM
KartRacer's Avatar
I've been interested to know how the bags ride in front with a setup running bags with the frowning leaves. I am planning on building a parallel 4-link for the rear and running bags, but for the front, I am still not sure what I want to do. I am concerned it would take too much pressure to overcome the sagging leaves to where the ride would still be rough at the proper height on the front.
MoPowa, I am still not sure if I would use heims or bushing type rod ends. Heims can be rough and noisy for street use, and with a truck like this you don't need crazy suspension travel.
