Clutch Switch
Re:Clutch Switch
I gave up on mine and installed a push button switch. I had a spare connector and wired it to a momentary on push button switch on the dash. I start the truck as usual but while the clutch is disengaged I push the button while turning the key. The switch cost about $5.00 and about 20 minutes to install.
<br>Bob
<br>Bob
Re:Clutch Switch
I pulled the connector off and stuck a female spade terminal over the two pins in the connector (I had to spread the spade connector a little). The truck thinks that the clutch is always depressed, and so far it has worked just fine. I don't know if there is anything extra attached to that signal on later models, though.<br><br>Alec
Re:Clutch Switch
My clutch switch doesn't work, but I'm more worried about putting the dang thing in first instead of reverse and driving through a storefront or driving over somebody's little car.
All the heavy trucks I've driven have reverse there, same with old 3 speed stuff I've had. I have to think about it every time I go for reverse.
Re:Clutch Switch
Monty -- <br>(On my truck) there is a sleeve around the push-rod that runs from the clutch pedal to the clutch master cylinder. The sleeve has the pedal return spring and the kill switch incorporated into it. It has a slot cut out of the side so that it can fit over the pushrod, and one end actually fits into a notch in the pushrod with a white plastic tab that slides in and locks it in place. It has been a little while since I fooled with mine. There is a cable that plugs into a connector on this -- I jumpered the two terminals of the cable together.<br><br>I hope this helps, if not, I'll look at the truck again and take some pictures.<br><br>Alec
lovin1stgens
Aug 31, 2018 09:49 PM
Barryn
Jul 14, 2008 09:30 AM
redramnc
Mar 28, 2005 06:58 AM
