Clutch safty switch
Clutch safty switch
Hey guys got some ???
my clutch safty switch is going out
and i don't wont to disable it because somtimes the wife forgets
. So i was wondering if anyone nows any P#s.
thanks
Jimmy
. So i was wondering if anyone nows any P#s. thanks
Jimmy
Obviuosly you haven't gotten her attention yet; I find a doubled up fan-belt works wonders.
Six manual-transmission trucks sitting out here and not a clutch-switch on nary a one of them.
You can dis-able/bypass the switch and route the two wires through a toggle-switch, such that the switch must be ON before the starter will engage.
If you develop the habit of ALWAYS flipping this switch OFF as soon as the engine starts, then if someone that has no business in a truck happens to bump the key, it will do nothing.
Also, you can wire one of those annoying BUZZERs on the cold side of this switch to remind you to turn it off.
Of course, this toggle-switch will not prevent someone cranking when the truck is in gear, but it should serve to remind them of proper starting procedure, which is :
Transmission in NEUTRAL
Clutch ENGAGED = pedal not pushed
Then START.
I dislike cranking an engine while holding the clutch-pedal down (dis-engaged); it is detrimental to the throw-out bearing and clutch-fingers, hence all of the dis-abled clutch-switches.
lovin1stgens
Aug 31, 2018 09:49 PM
GumpsVa
Mar 25, 2014 02:46 PM
Alwaysworking
May 29, 2008 10:28 AM
PapaSmurf
Sep 9, 2006 04:56 PM
redramnc
Mar 28, 2005 06:58 AM
