clutch problems?
Old Jan 11, 2007 | 02:34 PM
farmer0_1's Avatar
don't feel bad I have done alot of clutch jobs in my time and if it didn't have a problem I get lazy about checking run out on bell housings and flywheel. did have one bite me along time ago. maybe i should start check them again. lets see 15 min to remember where my dial indicator is or was. 15 min to check and remember what is acceptable on run out. = a good clutch job. just going to have to start again.
Old Jan 11, 2007 | 11:21 PM
dodgec68's Avatar
how do you check run out on the bell housing, or were can I get the info so when I d the clutch I can chek it
Thanks
Old Jan 12, 2007 | 12:20 AM
JimmieD's Avatar
You can mount your dial indicator with magnetic base and extension arm to the flywheel and then sweep the face of bellhousing where tranny mounts. This would indicate whether the input shaft, clutch, flywheel and pilot bearing are concentric. Concentric: is that the word I wanted? hmmm, well, don't know so how about 'lined up right'? You can sweep the flywheel by mouning dial indicator to block. If you do both then you'll be pretty sure of what's going on there.
ps: the factory service manual explains it in good detail. I don't have a way to scan the page or I'd send it to you. Maybe some other kind soul can oblige here?
DJ Turbo.
Oct 13, 2011 09:11 PM
Fishbait
Jun 6, 2006 12:34 PM
mbmrang
Jan 21, 2006 12:49 PM
kwhite4
May 9, 2005 03:22 PM
