Closed RWAL Valve Switch
Howdy,
My "Brake" and "Anti-Lock" lights are stuck on at all times... I grounded out the black wire to get the error codes and got 4 flashes. Based on information posted here in the past, that means that the RWAL valve switch is closed...
But what is the RWAL valve switch, where is it and how do I open it?
rwal is rear wheel anti lock its in the frame at the L rear of the truck ...follow the steel line off the axle and it will lead to it ... Have you tried to unplug the modual behind the glove box yet (about 30 sec. is all ) to reset it?
there are 3 switches built in to the rwal valve ,service manual states control valve is not repairable 1is reset switch 2 is dump sol. 3 is isolation sol. as best as i can tell is to un plug modual for 30 sec. to reset the system none of the antilock parts are serviceable it consists of sensor at dif. modual,and hyd. valve .
thats all i can help you with hope it helps
Robert
Robert
I think that's the same code I get on mine but I'm waiting on warmer weather to crawl underneath. I'm hoping it's a loose or shorted connector or wiring though. It's no telling on my truck. I found the entire left back brake had been gutted!
So check out all the wiring and reset the module by unplugging for 30 seconds and see if it works again.
I don't accept that the valve isn't servicable. I am adept enough that sometimes I can fix these things that Chrysler just replaces because it's cheaper for them and more profitable to sell the whole assembly than a repair kit. It's like them saying they will only sell you a new engine rather than selling you a water pump.
Edwin
Edwin
Edwin if you find a way to fix that problem would you post it here. mine has been that way for 4 years. rwal valve was 150$ 4 years ago which i would have bought but if it didnt fix i was stuck with it. dealer techs were a bunch of parts changers. not iknocking all techs. been there done that myself for 10 years. there are some really good ones out there. electronics aint my forte.
Rwal dump valve 97 ram diesel
where is this dump valve on the 1997 model. I only can find the proportioning valve. Have the same problem 4 flashes from datalink , replaced mc and reset module.
Howdy,
BearKiller
Oct 12, 2014 07:21 AM
bigragu
Sep 6, 2014 02:32 PM
