Clock Spring
Old Jun 8, 2017 | 06:17 PM
George Tucker's Avatar
Clock Spring
Will a 1996 Clock Spring work on my 1992.?. Both are 5.9 Cummins.
Old Jun 8, 2017 | 07:21 PM
johnh's Avatar
clock spring has nothing to do with 5,9, it's strictly dodge...call dealer
Old Jun 9, 2017 | 03:07 AM
boeingguy's Avatar
no 96 wont work. none available from dealer for long time now. a Dorman 525-104 should work( depending wether you have paddle switches or thumbar) but not plug and play , will have to splice in to existing wiring. it will have airbag wire which you wont use. but it will work
Old Jun 9, 2017 | 10:39 AM
eljefedavies's Avatar
I took one out of a junk Dakota for my 93. There was a write up about it but I cannot find it. I do not remember the exact years but since there were a lot more Dakotas made compared to our big trucks it was easier to find one in a junk yard. good luck.
Old Jun 9, 2017 | 10:06 PM
MrFusion's Avatar
If you're careful you can sometimes take a clockspring apart and re-solder wires where they connect to the housing. I did that on an XJ Cherokee clockspring once and it held for quite a while. Was still working when I sold the Jeep.
Old Jun 10, 2017 | 08:46 AM
mknittle's Avatar
One more reason I like my 1990. also no TPS and the voltage regulator takes less time to change that it takes to get the tools.
I don't know what I am looking at here but it looks good on paper.
cruise control clockspring bypass - Dodge Cummins Diesel Forum
92-93 Dakota is supposed to be the same from what I have read.
Old Jun 10, 2017 | 04:24 PM
I got lucky, i just checked our wrecking yard, they just got a 93 in a few days ago, whole right side missing, got side all smashed in a wreck, i bought the whole comeplete steering coloum wheel and all for $25.00.
Old Jun 12, 2017 | 06:08 PM
MrFusion's Avatar
You got a good deal there!
Old Jun 21, 2017 | 11:15 PM
Where is the Vacum dumped on my 9 2 W250, Cummins?.
Old Jun 21, 2017 | 11:27 PM
bigragu's Avatar
Are you meaning Vacuum pump? Where is the vacuum pump? Or dump?
Old Jun 22, 2017 | 11:10 AM
)n the cruise, where does it dump the vac, when you touch the brake.
Old Jun 22, 2017 | 11:55 AM
Nate-W250's Avatar
My guess is at the cruise servo. Which is what holds that vacuum. You should be able to find it on the drivers fender well. Should have a vacuum hose to it. I never really paid much attention but I would think all vacuum functions would have to go through there.
My clock spring broke as well. If you're looking for another alternative other than trying the Dakota/Parts truck replacement, here's what I did. I traced and pulled out the wiring and connected them to mini momentary rocker switches on the dash. There's an cruise on/off circuit which I wired together so its always on (I never understood why there's an option to turn your whole cruise circuit off? Either set it or tap the brake...done...). I have 2 momentary switches so you can push it once to SET, or hold to DECELERATE. Same with RESUME and ACCELERATE. Surprisingly, my horn still worked through my clock spring. You can find the wires easy enough with the factory service manual. Took me an afternoon and a few beers.
Good luck!
PS: Make sure you use blade-type connectors at the switches, in case you ever need to remove the dash its easier to 'plug' and 'unplug'.
Old Jun 22, 2017 | 02:34 PM
1STGENFARMBOY's Avatar
I did this on my 93 Dodge 5 years ago, still working fine.
94 dodge
May 4, 2007 10:46 PM
vavtx
Jan 7, 2006 06:47 AM
DieselNomad
Jun 15, 2005 07:34 PM
Flake
Jun 1, 2004 04:05 PM
