cigarettte lighter
cigarettte lighter
The wire(s) to my cigarette lighterwas cut by the previous owner. I saw in the wiring diagram which fuse goes to it , how do I rewire the lighter,? I just need it for cellphone charging etc. Is it as simple as just running a wire to the lighter.
Never looked at my '92 but most are grounded at their mounting point and have one hot wire that runs to a spade connector on the lighter. If I was starting from scratch I'd run a fused always hot wire to it so you could use it when the ignition is off too.
I bought a couple marine power ports that I plan to install in the console and use to charge things and get the cords off the dash.
Do like KRB says and just run a fused all-the-time-HOT wire to it.
That little bitty factory wire is just a truck fire fixing to happen.
Also, the way Dodge hooked it up, it is an extreme annoyance to have to have the key ON before it has power.
03CTDCO
Feb 28, 2005 05:35 PM
Maccandy
Jul 13, 2004 11:10 AM
