Check Those Transfer Pumps Fellas
Old May 4, 2003 | 02:29 PM
formula's Avatar
Re:Check Those Transfer Pumps Fellas
Found another one.....looks strangely familiar.....
With the 6-8psi output, maybe there's no need for a regulator...
http://store.summitracing.com/partde...=CRT%2DP4600HP
Old May 4, 2003 | 02:45 PM
Monty's Avatar
That last pump looks good on the psi specs. However, would a little more psi be better? Say around 10psi? Here is the Aeromotive regulator that the 24v guys are using. Aeromotive Regulator
Old May 4, 2003 | 05:12 PM
Jbolt001's Avatar
There's PSI and then there is GPH. WHat kind of GPH rating at what PSI is required? I have heard of some guys using the Holley pumps too. <br><br>Jay
Old May 7, 2003 | 11:10 AM
Paws's Avatar
What is the stock pressure for the lift pump on our CDT someone said about 7psi is that correct?. Could this be a source of low power in the low end also?
Old May 7, 2003 | 12:07 PM
Monty's Avatar
Paws...the psi should be around 6-7psi at idle. Yes, low fuel psi will effect the low end. But you should notice a top end lag before the bottom. Usually when the bottom end fuel psi drops off, the pump is toast. Mine was dead at 0psi idle. I noticed the top end more than the bottom.
Old May 7, 2003 | 04:25 PM
Jeeper's Avatar
[quote author=Jbolt link=board=9;threadid=14142;start=15#134862 date=1052086355]<br>There's PSI and then there is GPH. WHat kind of GPH rating at what PSI is required? I have heard of some guys using the Holley pumps too. <br><br>Jay<br>[/quote]<br><br>As I was reading this thread, I was thinking about the Holley &quot;red&quot; pump. I've used two of these on gas applications before with good luck. I believe they run $80-90. Holley also sells a higher pressure &quot;blue&quot; pump which I believe comes with a regulator. The Carter electric posted by formula looks good too. Might have to ask the manufacturers about using any of these with diesel.
Old May 7, 2003 | 06:07 PM
Monty's Avatar
Was at Autozone today browsing around. I found a mini fuel pressure gauge 0-15psi (Spectre brand I believe). It has a 1/8 NPT brass end. I picked it up for about 10 bucks. It works great with Rods 1/8NPT tapped high flow banjo fitting on the outlet side of the filter. I dont know how it will hold up with the pressure spikes of the transfer pump, but we will see.
RyeThomas
May 18, 2013 04:16 PM
CATCRACKER2
34
Jul 3, 2007 11:26 AM
Ilikebikes
Dec 11, 2006 10:13 PM
high country
Mar 9, 2005 07:22 AM
Duelin
46
Mar 12, 2003 08:56 PM
