Check this out for adding a WG.
Old Oct 19, 2011 | 10:33 AM
pwrtripls1's Avatar
Ebay ads not allowed on DTR
I was looking for turbo stuff for my denali and came across this. I have been thinking of different ways to bleed off some extra exhaust pressure and think this looks perfect! Its a T3 flange on both sides and I already have an extra 40mm WG sitting in my garage. I think a new route for me may be a DTech 62/65/12 for quick spool, an extra WG, and nitrous. Simular to Jasons setup. That should work very well for my application I think.
Old Oct 19, 2011 | 11:54 AM
CaptainChrysler's Avatar
You might look into mounting the WG right to the ex. housing, straight down right next to the inlet flange. There is usually lots of room directly below the housing with a single. That piece is cheap enough, but I can see it turning into a PITA having to redo the DP and other plumbing. Your WG has the two bolt flange?
Old Oct 19, 2011 | 01:30 PM
Falcon1's Avatar
Ricer garbage
Old Oct 19, 2011 | 03:34 PM
dieselJon's Avatar
Get a Steed Speed exhaust. Built in WG, either T3 or T4 housing, divided cylinders...
With it being undivided, I would worry about some spool up issues...
Old Oct 19, 2011 | 03:36 PM
Well that goes on the exhaust side...so how will that help you with the air pressure in the intake track?
Old Oct 19, 2011 | 03:38 PM
pwrtripls1's Avatar
It will keep boost pressure to a reasonable level, keep drive pressure down, and alow me to run lots of nitrous without overspeeding the turbo.
Old Oct 19, 2011 | 11:01 PM
TLRMAN's Avatar
PM your address I have one of them paperweights on top of the fridge... If you do take it I dont ever want to see it for sale some place...
Old Oct 21, 2011 | 12:32 AM
stillsmokin209's Avatar
For $625 just to add a wastegate? I'll pass...
Cut hole in manifold, weld in pipe with correct flange, attach wastegate. Done.
Old Oct 21, 2011 | 07:51 AM
pwrtripls1's Avatar
The part I'm looking at is nice cast iron, direct bolt in, and under $30. Plus it will look better and be easier to hook up the WG outlet to the DP since it will mount on the back side there the exhaust is. I'll go ahead and get one, and be the genea pig to test it.
Old Oct 21, 2011 | 07:07 PM
dieselJon's Avatar
Did you read and look at the website?
Doing more than adding a W/G. The major thing I see is the lack of a dividing flange. No warping, no cracking, better flow, any flange you want...
Old Oct 23, 2011 | 09:46 PM
pwrtripls1's Avatar
Well im short on time before the track. So tomorrow im going to order one of these and try to get it overnighted. I still need time to install and test it before next saturday. I held off ordering and shouldnt have.
Adam3291
May 2, 2008 10:08 PM
bsj04
Jun 27, 2007 11:16 AM
Gary C
Mar 15, 2004 02:53 PM
