Changing Windshield
Old Apr 23, 2007 | 01:07 PM
Chipappa's Avatar
Talking Windshield Woes
The method described by gozapper is right on. Two people with fiber or plastic "bones" as we called them in the business. Top first because if you install bottom first you will almost always break it when you get to the top corners. Soapy water solution for lube, or plain hand cleaner -brushed on. Don't use silicone! You're gonna want to seal it and silicone will prevent the sealer from sticking. These windshields are prone to leaking anyway. Also depending on which locking bead it has, round rubber or the funky shaped chrome colored plastic, you may need a special tool to insert it without driving yourself nuts, and even then the plastic one can be a bear. The "rope trick" is suitable for installing the back glass but not very useful for the windshield. If you're using a used windshield, check it over carefully. Use a pro if he's familiar with the old stuff. Lots of auto glass guys are new to the business and won't know how to go at this one properly. Make sure they'll stand behind their work if it leaks.
Just some advise from an old pro who was in the business for almost thirty years.
Old Apr 23, 2007 | 02:09 PM
92DIESEL's Avatar
Thank you very much, I think I'm scared straight now I am going to leave this one up to the pros
Thanks again,
Michael
Old Apr 23, 2007 | 02:46 PM
farmer0_1's Avatar
how about my next trip thru northern idaho you have a little how to class i will bring my good glass. just kidding. but i do make it thru once in a while heading from portland oregon to bozeman mt. sure alot of new rigs parked at mr. smiths motors.
Old Apr 25, 2007 | 12:17 PM
Dolph's Avatar
Did my 1st gen. about 9 months ago. Take your time, use the rope/string trick and lots of soap (i used dish soap). My total job took about 3 hrs with cutting out the windshield from my 74 ramcharger to put in the PU. The fit is tight but just take your time.
Old Apr 25, 2007 | 12:41 PM
gozapper's Avatar
Windshield Woes
My next one will be rubber in frame, top in 1st, bottom last!
And lots of soap!
Tom
KATOOM
15
Apr 14, 2003 02:21 PM
Dieseldude4x4
Mar 16, 2003 10:00 PM
BigBlue
Mar 15, 2003 06:48 PM
WA4SLC
Feb 10, 2003 04:54 PM
Holsteinman
Feb 5, 2003 09:26 PM
