Changing oil in 92 five speed trans
Old Sep 14, 2003 | 02:05 PM
thumbs's Avatar
have a 92 W350 I want to change the oil in the transmission and from what I get I should over full by a quart or two. First of all what is the best(or easyest way) to over fill it? Second is Mobil one a good oil for the trans? I do a lot of pullin with er. I tow a 12K fifth wheel.
Thanks for the help
Gary
Old Sep 14, 2003 | 02:14 PM
Monty's Avatar
Re:Changing oil in 92 five speed trans
The best way that I have found to overfill is to take the top PTO cover bolt out and use a suction gun to push the oil in the tranny. The book calls for 3.5 qts of oil, I usually just put an extra quart through the top bolt of the PTO cover.
Mobil 1 5w30 Full Synthetic is the preferred choice of oil to use in the Getrag.
Old Sep 14, 2003 | 04:57 PM
I replaced the drain plug with a close nipple and an elbow, aimed the elbow straight up and poured the stuff in with a small funnel, then capped it with the original drain plug. Worked for me. I'm using Redline MTL, but lots of guys are happy with Mobil 1 5w-30.
Old Sep 14, 2003 | 05:42 PM
thumbs's Avatar
Ok thanks guys. Hey got the Mobil 1 and was lookin on the specs. The requirementsI have are from the 1992 service manual. The letters and requirements aren't the same. Do these new numbers on the Mobil 1 container superceed the old 1992 requirements?
Old Sep 14, 2003 | 06:10 PM
Yeah, they probably call for an SG rated oil, the new rating (they're up to SL I think) supersedes the old ratings.
Old Sep 14, 2003 | 06:38 PM
thumbs's Avatar
Hey wannadiesel
When did ya get your gauges in? Last I heard you were without.
Old Sep 15, 2003 | 04:08 AM
Still living dangerously. It's not really that bad, I've only messed with the fuel pin and star wheel, and the smoke screw is actually turned all the way out. Just spent some $$ redoing the ball joints and control arm bushings, so it'll be another few months.
Old Sep 17, 2003 | 07:20 PM
thumbs's Avatar
Hey be real careful. Those temps can get up there pretty fast. I spent a couple of hours tryin to tune the pump while pullin the trailer. I'm trying to ballance the temps with the power.
Old Oct 3, 2003 | 06:03 PM
mightyrat's Avatar
you mean i aint gotta use a crane to tilt the truck on its side anymore? crane rental can get expensive
Chris Derrick
Jan 15, 2010 04:51 AM
farmer0_1
Sep 13, 2006 10:37 PM
TPilaske
Dec 26, 2003 03:42 PM
Pickle
Oct 29, 2003 06:10 PM
PADZZ
Mar 28, 2003 04:33 PM
