Is This The Cause of My Getrag Problems??
Old May 10, 2008 | 10:32 AM
nate_o23's Avatar
Hello I have a 91 Dodge. I have been having problems shifting the Getrag. It gets caught in neutral between gears. I dropped the tranny today and removed the top cover. When I did, a piece of the big spring that puts tension on the shifter fell out. It was broken about 1/2" from the top. Could this be the cause of my shifting problem? What else can I check in the top cover because I dont want to put everything back togather only to find out that wasn't the only problem. Thanks for any help!
Old May 10, 2008 | 11:52 AM
BearKiller's Avatar
That is most likely the shifter-centering spring.
Actually, there should be TWO of them, one each side; on a normal transmission, with the shifter in NEUTRAL, you can feel these springs when you shift right and left of center in order to follow the H-pattern.
Yes, that could very well cause your shifter to hang up in neutral.
Old May 10, 2008 | 12:34 PM
nate_o23's Avatar
Actually its the big cone shaped spring that pushes against the shift lever that is broken. Sorry for the vague description in the first post. I forgot there is more then one spring.
Old May 10, 2008 | 07:40 PM
nate_o23's Avatar
I went out and looked at my shift cover again. Were are the 2 springs you are talking about?? All I saw was the one big spring.
Also Does anyone have a copy of the getrag manual they can email me?? That would be a HUGE help. my email is
nate_o23@yahoo.com
THANKS!
Old May 10, 2008 | 08:57 PM
BearKiller's Avatar
The manual does not show any dis-assembly pictures of the shifter/forks assembly and says they are not repairable, but to replace the entire unit.
I know that to be wrong, because the local transmission shop has bought new replacement parts and over-hauled hundreds of them.
I may be thinking wrong; but, on each side of where the end of the shifter engages the forks, should be a spring-loaded plunger that centers the shifter between 3rd-4th gear; to shift 1st-2nd or 5th-REV the shifter goes against spring pressure; at least that is the way of it in most transmissions I have messed with.
Someone more smarter than me will straighten me out if I am wrong.
If I weren't so computer-illiterate, I would E-mail a copy of the manual; untelling where it would end up if I tried.
Old May 11, 2008 | 12:13 AM
Alwaysworking's Avatar
alwaysonDTR
manual sent, check the roll pins that hold the forks to the shaft they slide on, i had one brake 1-2 and thats not good when you have a loaded trailer
Old May 11, 2008 | 05:58 PM
nate_o23's Avatar
Thanks guys for the help, and THANKS for sending the manual. Hopefully a new spring will fix my problem
chumstone
Sep 29, 2007 04:06 PM
Jordan5687
Mar 14, 2007 07:00 PM
lezmark7
Aug 24, 2006 10:07 PM
Tree DR
17
Apr 29, 2006 10:21 AM
Clint
Nov 28, 2004 04:04 PM
