can't identify my transfer case
Old Apr 11, 2007 | 01:38 PM
phantom_ram's Avatar
After blowing out my u-joint and having to replace the shaft I noticed that the front out put seal is in bad shape. I went to the parts store and there are two transfer cases for 93 205 and 241. I looked under the truck and can't find a tag to determine what I have. I'm guessing 205 since the seal is more $$$ and has to be ordered. Is there a way to identify it without a tag?
Old Apr 11, 2007 | 01:47 PM
Free89W350's Avatar
if you cant find the tag I would suggest finding a casting # and checking with you local Dodge dealer to see if they can tell you which one you have. someone here might beable to tell just by looking at it but I can't. Hope this helps you out. Ryan
Old Apr 11, 2007 | 02:01 PM
jer1's Avatar
If it's a big ol chunk of cast iron, it's a 205. 241's have an aluminum case. Did they put the 241 behind a Cummins? I thought they were just for v8 gassers.
Old Apr 11, 2007 | 02:16 PM
Thats what I figured about the transfer cases one diesel and one gas but I wasn't sure. I think its steel/iron something pretty stout. Everywhere I spoke with have 241 parts and no 205.
Old Apr 11, 2007 | 02:59 PM
A_port93's Avatar
I am almost 100 percent positive that it is a 205. i dont think that they put 241s behind this year of truck and i do remember that 93 was the last year they used the np205 which is not chain driven like the later model ones..is the 241 tcase a passenger side front diff as the 205 is?
Old Apr 11, 2007 | 03:02 PM
Ace's Avatar
Ace
It's gotta be a 205. Try scraping around the PTO cover on the driver's side and see if the tag is just covered with dirt/grime.
Old Apr 11, 2007 | 04:20 PM
EClancy's Avatar
its a 205, its the only one that came behind a pre 94 cummins
Old Apr 11, 2007 | 05:33 PM
G1625S's Avatar
yeah, none of that sissy la-la aluminum stuff under a 1st gen....cast iron 205 is what ya got
Old Apr 11, 2007 | 06:29 PM
DODGE 92's Avatar
tc
its a 205 no nanuminium gona last on these beasts
Old Apr 11, 2007 | 06:52 PM
SuperiorRam's Avatar
front u joint Precision # 315G (not the cv joint) rear is a Dana 1410
it is a 205 gear to gear
First Gen Cummins is THE LAST REAL TRUCK !!!!!!!!!!!!!!
LOCK OUT ON A DANA 60 FRONT (KING PINS TOO)
AND A GEAR TO GEAR T-CASE
THE DEFENCE REST YOUR HONOR
Old Apr 11, 2007 | 06:53 PM
I didn't know the 241 was aluminum cased. Every part store in the area has to order the 205 seal so that is a good sign that it is what I have.
Thanks for all the help
Sharp929
Jun 5, 2014 10:03 PM
wyododge
Aug 18, 2011 07:48 AM
REDNECK-WELDING
Mar 5, 2009 10:39 PM
justdirt
Oct 6, 2004 02:32 PM
