Preparing to swap Getrag 360
Another thing I thought of, will I need to swap crossmemebers? The truck im getting the setup from is complete and I need to let him know everything I need. Thanks.
The cross member LOOKS the sane, from being under both an auto and manual, but I dont know if they are, or the location in relation to the engine is the same. Best thing to do is tell the guy "maybe" you'll need it and see when you get to that point.
Driveshaft will be different length for sure.
Daniel
Daniel
The driveshaft will definitely be different, probably with a carrier bearing; get that cross-member, also.
Transmission mount will most likely be different, so get it and the transmission cross-member.
Don't forget the under-the-dash pieces, including the clutch AND BRAKE pedals.
Also, clutch master and slave cylinders/lines.
Picked up everything this morning. $700 for everything, almost. I need slave/mastercylinder and tubing. I found those on ebay. Do I need the flywheel housing? I found one on ebay too, just need to know if I should get it.
I had to shorten the front half of the two piece driveshaft about 2.5 inches, as the getrag is a bit longer... same carrier... same rest. DIFFERENT crossmember.... I have done this swap, lmk if you have any questions!!
my truck is a 2wd btw
I'm positive that you would need the driveline. Not sure about the crossmember.
