can't get the idle down
Old Sep 18, 2005 | 04:04 PM
lovemysan's Avatar
Okay I have the power screw in about 3-3.5 turns. I turned the low idle stop screw in to bring it down. But this didn't help, the throttle doesn't hit it anymore. What do I do?
Old Sep 18, 2005 | 04:33 PM
G1625S's Avatar
The throttle linkage may be holding the pump from settling back against the low idle stop screw. Try lengthening the throttle rod between the ball studs. It works like a turn buckle. You may then have to re-adjust the linkage on the top of the pump to get WOT. Hope this helps.
g
Old Sep 18, 2005 | 09:47 PM
rebal's Avatar
you may have to back the fuel screw out a bit ...watch for runaway that will tell you if the screw is in to far.
Old Sep 18, 2005 | 10:31 PM
59FORD's Avatar
Sounds like too much on the full power screw.
If you miss the run away, you'll only do it once
59
Old Sep 19, 2005 | 01:33 AM
frostie's Avatar
leave the fuel screw there. if the throttle isnt coming back to the adjuster screw then you have to do some linkage adjustment.
There is a metal bracket with a spring that is part of the throttle and cruize control linkage. there is a metal tab that limits the travel. you need to grind some metal off of it to give your linkage more travel, forward and in full throttle position. You may have to look at it for a bit but you will see what Im talking about. good luck
Totallyrad
Jul 19, 2011 07:41 AM
DAN POUCHER
Jun 14, 2008 06:52 PM
DAN POUCHER
May 7, 2008 07:23 AM
MikeThomas
Apr 24, 2007 01:48 PM
