Camper tie downs
Old Feb 2, 2018 | 09:28 PM
bigredbrick's Avatar
Camper tie downs
Just getting started. For the rear, I was thinking I could just slide it in there but then realized that the bumper will have to come off . It's going to be fun breaking the rusted up bolts loose. Cardboard template will be 1/4" plate that will be bolted to the very rusty hitch with 3, 3/8" grade 8 bolts each side.
The front tie point will be below the rear cab mount with a hole through a rocker protector for the removable anchor. I will be splitting 3" square tubing to create 3"x1 1/2" channel for the rocker protector that will run from behind the front tire to rear of the cab. Advice appreciated, usually!
Old Feb 2, 2018 | 09:35 PM
peckens's Avatar
That truck doesn’t have a single rusted bolt judging by the pictures!
Old Feb 2, 2018 | 09:42 PM
That is what I was seeing as well.
The rusted bolts I see often have the head on them that looks like a crusty Milkdud not a bolt head.
Regardless nice work on the tie downs.
Old Feb 2, 2018 | 09:48 PM
Sheesh, I guess I'll have to get more light on the frame next time! No, the rust isn't midwest or east coast severe.
Old Feb 2, 2018 | 09:51 PM
We are just jealous...
Nice looking brick there!
Old Feb 2, 2018 | 09:59 PM
What the picture doesn't show is the solid rust patina hood and top with failing clear coat working it's way down the sides!
Is there any difference between welding hot rolled and cold rolled steel?
Old Feb 3, 2018 | 02:13 PM
MrFusion's Avatar
Patina and clear coat problems?!?! You California crybabies!!
It's all rot holes and rust piles here (PA) my friend!
There IS a difference between cold and hot rolled steel. Here's a link:
Materials 101: Hot Rolled Steel vs. Cold Rolled Steel | Mid City Steel | Steel Supplier- Rebar Fabrication - Steel Sales & Service- Westport, MA - Bozrah, CT
Old Feb 4, 2018 | 09:39 PM
Some more progress. Man I am slow! I'm a wood butcher not a steel fabricator.
I had to do a lot of grinding on the welds. I have the strength down, just not the pretty. A drill press would be real nice to have. I got a set of Milwaukee Red Helix bits, they work real good.
Attached Thumbnails Camper tie downs-img_20180204_113452.jpg   Camper tie downs-img_20180204_174314.jpg   Camper tie downs-img_20180204_174326.jpg
Dodgezilla
Apr 10, 2004 05:22 AM
perk
Mar 8, 2004 11:33 PM
CRXsi
Mar 1, 2004 07:31 PM
Abcowboy
Mar 11, 2003 08:31 PM
boatpuller
Jan 20, 2003 11:58 AM
