cab swap
Old Dec 28, 2007 | 09:56 AM
  #46
deking1970's Avatar
Does your truck have power windows and locks? If not that two wire plug is probably a speaker wire. My truck has power windows and a lot more wires there.
Old Dec 28, 2007 | 10:00 AM
  #47
ryan10's Avatar
No my truck has manual windows and locks. come to think of it, i do think its a speaker wire. thanks. are the 2 bolts behind and to the left of the glove box the only 2 bolts behind there, or are there 2 more?
thanks.
Old Dec 28, 2007 | 10:12 AM
  #48
deking1970's Avatar
Those are the only bolts back there.
Old Dec 28, 2007 | 10:14 AM
  #49
ryan10's Avatar
Ok, thanks for all your help. id assume since i dont have power windows and locks, i dont have the wiring harness's in the doors. so now i just have to find the vacuum lines. i found 2 small lines that run through the firewall, are there more than this?
thanks.
Old Dec 28, 2007 | 10:22 AM
  #50
deking1970's Avatar
Those 4 lines behind the glove box (red, black, and 2 shades of green) are the vacuum lines they stay attached to the blower housing you unplug them up behind the heater controls. The two lines your talking about don't actually go through the fire wall, that is part of the blower housing also. When you swap out the blower housing all of the vacuum lines will go with it.
Old Dec 28, 2007 | 10:30 AM
  #51
ryan10's Avatar
Ok, thanks. it should be a little more clear when its torn apart.
Old Dec 28, 2007 | 11:05 AM
  #52
kah68's Avatar
So I guess at $ 300.00 for a used body, my idea for an aftermarket fully galvanized, user friendly cab is not a very cost effective idea.
Old Jan 13, 2008 | 07:36 AM
  #53
ryan10's Avatar
Well guys I finally picked up the body: Here are some pictures of me bringing it home
Old Jan 13, 2008 | 04:58 PM
  #54
DNRCustoms's Avatar
Man, that box looks good. How bad is your cab? Have you thought about just repairing some of the rust damage insted of swapping it out?? If yu don'nt mind me askin' how much did you pay for the cab and box? Looks good. Looks like you got some work to do now
Old Jan 13, 2008 | 05:03 PM
  #55
ryan10's Avatar
I paid 300 for cab, fenders, doors and the bed. Im just gonna go ahead and swap the cabs, from what ive heard its pretty easy.
thanks for the comments
Old Jan 14, 2008 | 07:46 AM
  #56
DodgeFreak's Avatar
Where are you located??? Also when you get ready to pull the cab if you haven't i'd pull your wheels and set the axles on the ground (place a piece of wood under the 4 hubs so it doesn't damage anything) that way its closer to the ground to pull the cab and you don't have to lift it so high well as high anyways....
Old Jan 14, 2008 | 07:19 PM
  #57
SkinnyBTN's Avatar
Hey guy's! I dont mean to steel a thread or anything, but if yall dont mine me askn? I found a '85 crew cab dually 2wd that I am thinkn of buying and swapping my cummins into. My ? is with a little roof rust, not much, and that bieng the only rust, would it be worth $1000. I haven't seen alot of dually crew cabs with a straight body around my parts. Time and effort are not a worry to me, just the $ aspect.
Old Jan 15, 2008 | 07:51 PM
  #58
DodgeFreak's Avatar
I'D Say so, We bought ours for 400 bucks no rust but it wasn't a dually and it had no front clip or motor or trans. so if its complete then i'd say so you could always resell the parts that you pull out.
Old Jan 17, 2008 | 04:49 AM
  #59
KRB's Avatar
KRB
Long as the cab rust is surface only and not the bad cancer from within!
jj3500
Mar 27, 2014 01:05 PM
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
MDLP412
Oct 8, 2007 04:13 PM
moTthediesel
Dec 27, 2004 08:09 AM
