A/C temp cycling switch?
Old Sep 8, 2008 | 07:39 PM
TJE's Avatar
TJE
I have a new switch for my 91.5. To put the new switch on will I have to remove the freon, or is it just a bolt on?
Thanks, Tony
Old Sep 9, 2008 | 04:49 PM
The sensing probe just slides in the tube.
Old Sep 9, 2008 | 05:58 PM
TJE's Avatar
TJE
Thanks, wanna
Old Sep 10, 2008 | 01:49 PM
samiam4's Avatar
Let us know how it goes.. tight amount of room there. PM me and I can make some suggestions if you have to break into the system.
M
Old Sep 10, 2008 | 03:57 PM
QIK2D's Avatar
is this the temp switch or the low pressure(cycling) switch. the low pressure switch screws into the side of the expansion valve. removing it will empty the system in short order. the temp switch just slides into the tube on the liquid line. no loss of freon in removal as suggested. might want to make sure which you need.
Old Sep 27, 2008 | 09:24 AM
TJE's Avatar
TJE
Up Date
I've began installing the temp cycling switch. The probe that you slide into the tube....is about an 1" to 2" too long. What I mean is....there is that amount of the copper probe still showing even though I've pushed the probe as far as it will go. ? What do I need to do? cut it off, wrap it with tape of some sort?
Thanks, Tony
Old Sep 27, 2008 | 09:43 AM
Tron's Avatar
Do not cut the probe. have you checked to see that there is nothing in the hole. If its ok and thats how the tube sits it should be ok just as long as its secured in place.
Old Sep 27, 2008 | 10:07 AM
TJE's Avatar
TJE
There is nothing blocking the hole. The probe is 5.25" long, and it slides into the hole 4" leaving 1.25" not sliding into the hole. I was just wondering if that 1.25" of copper needs to be covered with something?
Thanks, Tony
Old Sep 27, 2008 | 04:41 PM
TJE's Avatar
TJE
Up Date
Hello everyone. I got the temp cycling switch installed, and took the truck for a spin. The temps never get down below 50 deg. and it will cycle off and not come back on....for 5 or so miles.....if it comes back on at all! So I did some searching on the forum. I checked the low pressure switch by jumping the switch. The compressor will kick on every time! Is my problem the LP switch?
Thanks for all your help, Tony
Old Sep 27, 2008 | 07:09 PM
Sounds like the system is low on refrigerant. What are the pressures?
Old Sep 27, 2008 | 10:18 PM
TJE's Avatar
TJE
Not sure what the pressures are....I'll check them and get back with you.
Later, Tony
Old Sep 28, 2008 | 12:37 AM
farmer0_1's Avatar
i did the fix on the cycling switch and recharged with r12 wow is that thing cold.get rid of the cycling switch and put on a coat.
Old Sep 28, 2008 | 01:54 PM
TJE's Avatar
TJE
I tried that....problem is where I'm at there is too much humidity, and it freezes up.
Old Sep 28, 2008 | 02:50 PM
TJE's Avatar
TJE
Later, Tony
I went and bought one of the cheaper gauges to check the pressures with. I had to jump the low pressure connector to get the compressor to kick in. The ambient temp is about 80 deg. The gauge says the low pressure at this temp should be between 40 to 50 psi. At 85 deg it should be 50 to 55 psi. Mine is reading at 35 psi.
So it looks like my A/C is slightly low on freon....but is it enough to keep the compressor from kicking on, or is it the low pressure switch that is faulty?
Thanks, Tony
Jim Lane
Jul 31, 2019 03:12 PM
sixgun4x4
Dec 8, 2008 09:19 PM
dogman
19
Aug 29, 2008 08:27 AM
kawi600
Jun 4, 2006 03:13 PM
hlc
Aug 24, 2003 06:59 AM
