A/C quit
Old Jul 29, 2005 | 12:53 AM
frostie's Avatar
A/C quit
I got my A/C working about 2 weeks ago. It was working like a champ. Then I noticed my voltage dropped and realized my alternator quit, so I shut off my A/C. I ended up doing the external voltage regulator to cure my charging problem. now that it is working I turned on my A/C and I have nothing, no blower motor and compressor does not come on, The freon is OK.
I checked further and found no power to the breaker in the fuse panel for A/C and heater. checked further and found a relay up by the park break, that relay feeds the fuse box. There is no signal to the relay, It does have power to the larger red wire. does anyone know where the relay gets its signal.
Old Jul 29, 2005 | 11:47 AM
Grey Wolf's Avatar
Sounds like the "brain" (PCM) died taking out your alternator and AC
Old Jul 29, 2005 | 03:14 PM
Actually it sounds like the crank sensor.
Old Jul 29, 2005 | 03:25 PM
Alec's Avatar
To be fair, a faulty crank sensor will make the ECU appear "dead" . . . Aren't there a few other things that would be affected too, though?
Old Jul 29, 2005 | 03:27 PM
Unless he has cruise control, no. He has a 6 speed, so no overdrive issues.
Old Aug 1, 2005 | 09:01 PM
frostie's Avatar
Well it appears I have a problem with the ignition switch. part of my fues box does not have power, hopefully I will have some time this evening to look it over.
Thanks for your advise
Rampuller
Mar 15, 2003 05:35 PM
MoParr
0
Feb 16, 2003 01:26 AM
bigbaddiesel
Dec 28, 2002 01:44 PM
Garz
Nov 17, 2002 02:02 PM
DarrellB
Oct 6, 2002 07:31 AM
