A/C coil replace
Old Aug 23, 2006 | 03:01 AM
loch's Avatar
A/C coil replace
Just thought id give a heads up, as you know my a/c coil under the dash (i though) needed replacement. So after cussing kicking and bleeding it did not cure the smell i was noticing. However i did discover the fan control switch is prone to fail, it allows the smoke to be sucked into the vent. So if any of you happen to smell an unusual oder while a/c is on, check that switch, it will save some headaches.
joem
Apr 22, 2012 10:46 AM
stonewalldiesel
Apr 15, 2011 07:41 PM
jt
Mar 20, 2003 08:54 PM
zeik
Mar 18, 2003 07:44 AM
TXBobcat
Oct 23, 2002 09:56 AM
